03-11-2005, 05:46 PM | #1 |
700r4 - can't drop pan?
The pan bolts on the tailshaft end of my 700r4 are inaccessible because of the auto crossmember - I can see the bolts but there's no way to wrench them. Should I jack up the tranny from the tailshaft end? Would that put too much strain on the tailshaft? There's no driveshaft in yet...
03-11-2005, 05:48 PM | #2 |
its all about the +6 inches
While I don't like doing it, I have jacked up quite a few like you describe.
Have you tried a 1/4 inch set with a universal? I find that helps in some aplications. |
03-11-2005, 08:42 PM | #3 |
...i jacked mine up on the pan..unbolted the crossmember and slid it back then let the jack down so the tailshaft rests on the crossmember
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
03-11-2005, 10:16 PM | #4 |
I recommend working the tranny like mooneyes4b says. You can also use a 2x4 to "space" between the tailshaft and the cross member while you unbolt the pan.
03-11-2005, 11:06 PM | #5 |
whats the difference between a crossmember holding it and a jack holding it?
It'll only be up for a few seconds while you unbolt the 3 or 4 pan bolts, then you let it down...and jack it up again to re-install the bolts. Smae amount of time jacked up either way, and doing it with a jack saves 30 min at a minimum on removing the crossmember. |
03-11-2005, 11:41 PM | #6 |
Watch out for your cornhole !
Tx Firefighter method. Put a small 2x4 block of wood between the tailhousing and crossmember.
The wood block will hold the back of the trans up.
03-12-2005, 12:57 AM | #7 |
Thanks Tx Firefighter. I didn't explain what I meant very well. Too much vodka.
03-12-2005, 06:14 PM | #8 |
When I did mine using an original auto crossmember, I trimmed the front lip off the crossmember so that I could access the bolts without going through all the headaches that are being discussed here! Did add an 1/8 inch plate to the inside of the U channel for added strength not that it should really need it.
Smitty '71 Short Fleetside Spring Valley, Ca. |
