rear axel question
Hi, I have a 71 GMC 3/4 4X4 with a single rear wheel axel...now my question...will a set of dual wheels fit in place of the single wheels? I tryed a dual wheel on and it fits but the back of the rim sits tight against the outside edge of the brake drum. The wheel seems to fit good otherwise just only tight against the outer brake drum. It's a flatbed so room under the truck for dual wheels isn't an issue. Thanks.
user # 2756
![]() Join Date: Jun 2001
No the duallys have a spacer on the hub to deal with the 7" or so of backspacing of the dually rims. The rim mounting surface would not be sitting against the hub it's self.
Welcome to the board. Post some pics of your truck.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Thanks for the quick reply. If I added a spacer would the wheels fit? The wheels hit the drum just as the lugnuts are tighted down. The only other issue is the studs I have now are just long enough for the dual wheels but not long enough if I add a spacer.
You could ask for some duallie hubd and drum..that might be cheaper if you could get them without a large shipping cost. Ya Never know who's local and has something possibly.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
