Old 03-11-2005, 09:34 PM   #1
billsbowtie
billsbowtie's Avatar
Ft.end ?
help with a ? will 73 spindels work for 68 and if so how many years up will work thanks for any help
billsbowtie is offline   Reply With Quote
Old 03-11-2005, 10:38 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
bill i got 81 stuff under the 67 but i had to use the a arms and the disk brake proportional valve and master cyd and booster well i used everything from the 81 front end including the steering box and power steering pump !!!!!!!! everything was a bolt on except the brake rod form the petal to the booster i had to make one of those
theres a differance in the fittings on the 80 and up stuff there metric and the 79 and older ones are all standard fittings on the brake lines
tnblazerk5 is offline   Reply With Quote
Old 03-12-2005, 03:59 PM   #3
billsbowtie
thanks rob
