Old 03-11-2005, 11:50 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
vacuum line question
what can i do to hide the vacuum booster line? it interferes SEVERELY with my valve covers where it is now and i plan on buying tall aluminum ones here soon and it's ugly looking.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 03-11-2005, 11:57 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I always just build a new one from scratch. That way, you can make it any shape you need.
Here's one I built awhile back.
Old 03-12-2005, 12:01 AM   #3
67ChevyC10Stepside
hmm...could i just cut it off straight behind the carb and run a long rubber line down behind the valve covers to hide it?
Old 03-12-2005, 12:02 AM   #4
Tx Firefighter
Sure, just make sure and use good hose that won't collapse under vacuum.
Old 03-14-2005, 10:39 AM   #5
Putter
More Cowbell....
Putter's Avatar
Almost finished with my swap, I am making all my vacuum lines out of steel, and routing them around stuff to hide them. Looking really good, but most likely annoying my help (G-Man69) with the extra delay tie!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 03-14-2005, 11:16 AM   #6
cwilkie
Chance
cwilkie's Avatar
Vac. Line
What are these made out of and what size is needed? What do they hook up to...carb &/or manifold?
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 03-14-2005, 12:03 PM   #7
Putter
More Cowbell....
Putter's Avatar
Mine runs to a vacuum port behind my carb. Mine is actually on the intake. I used 3/8" steel line as much as I could, then connected it with rubber hose.
