03-12-2005, 12:03 PM | #1 |
69 motor mounts and 76 motor mounts
I parted out a 76 with small block and I notice a diff. in motor mounts to my 69 with a 350. The 76 has the long bolt that runs front to rear. Are these usable in a 69 ( bolt in ) or not????
Thanks, DaVE |
03-12-2005, 03:51 PM | #2 |
67-72 parts collector,…
No. You will have to use '69 style motor mounts. Your '69 frame stands will not accept the '76 style motor mounts. I don't think you can swap in the frame stands off the '76, either.
03-12-2005, 04:09 PM | #3 |
I follow you! Thanks for the info. Saves me a lot of wasted trial and error. The long bolt style looked easier is why I wondered.
Thanks, Dave |
03-12-2005, 09:11 PM | #4 |
CCRider
With drilling a couple of holes and puting some spacers on the frame they will work but you have to use the whole thing towers and all
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
03-13-2005, 12:29 AM | #5 |
My 74 bb stands wouldnt bolt in because the 74 1/2ton had a taller frame. But I had a set of 73 sb stands and they bolted right into my 70. Also my 454 bolts right into the 73 stands and the headers clear.
