Old 03-12-2005, 04:33 PM   #1
72MARIO
72MARIO's Avatar
Removing bottom leaf for a bit more drop.
I have a 67 shorty and leaf spring suspension. I have a 5 pack of springs and a really big spring on the bottom of the pack. I will not be towing or hauling anyting in the box. Would there be a problem taking that spring out ? I can't find a reason not too I think it will give me that extra 1.5"-2" drop I want.
Thanks,
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-12-2005, 08:36 PM   #2
69 longhorn
The flat helper leaf on the bottom can be removed, but i doubt it will drop you much(about 1/2", or about the thickness of the leaf). the helper spring is not part of the load rating on the spring , untill you have enough weight on the truck to squat the springs...... L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-12-2005, 10:06 PM   #3
72MARIO
72MARIO's Avatar
That what I thought. I am never going need it the axel will hit the frame long before I need the lowest spring. What are you running for slapper bars
2005 TAHOE DD
Old 03-13-2005, 12:15 PM   #4
69 longhorn
I have a cheap pair of Lakewood slappers, that clap onto the springs($30 or so through summit or Jegs). my ubolt plates are made from heavy flat plate steel (3/8 " ), & the rear of the bar is bolted to the U bolt plate. This lets the snubber hit the eye of the spring (short bar). Clamped about midway on the front half of the spring, & a set of ubolt/bar clamps approx 1ft behind the axle, they work pretty well on my longhorn. bear in mind that these are universal car slappers, & I have flipped the axle on my truck.......you will need longer brackets if your axle is under the spring. Best of luck,69L
