I am wondering if the 1/2 ton rear end that I have right now will be enough to have a large camper in my LB. I have leafs as well but is it enough?.....cause I wish to pull a boat behind at the same time as well.....if I was to upgrade to 3/4 leafs and rearend, how would this be on my milage?....or would it be the same....I know I have to swap axles if I want 5 lug.
3/4 ton not avalible in 5 lug better have some overloads on there
Collector of rusty Items
I would suggest a newer Corp-14 axle. I am using a 79
They are bombproof. I have run thay for 20 years with no problems. The 3.73 is the best ratio. On a 2wd the spring pads will line up, but you will have to change the shock mounts. You will end up with 8-lug wheels. Get some 16 inch rims and rum 265 R 70 16 tires and you will be a happy camper.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
