Old 03-12-2005, 09:48 PM   #1
3100 special
Street Rod Dreamin'
3100 special's Avatar
Location: Work:Batam, Indonesia/ Home:League City, Texas
Talking Beautiful day here...got a little done on the project
Great weather today...sun shining but, not too hot.
Took a patch out of the bad section that I bought the patch for (see Got My First Patch Panel) and cut a patch to cover the old gas inlet. I'll be buying a Hagan gas door/housing to weld into the back left corner. Pulled out one of the back fenders and sanded it completely down inside and out. There was a small section of rust through in one spot where the fender was bolted to the body. Cut it out and cut a piece to weld in. All of my welding is on hold until I get some gas for the MIG. Started sanding on the other fender but, I was asked to stop and cook some steaks on the grill...NO PROBLEM!
Long day though. This truck has four layers of paint, original primer, dark blue, white then, the gold on top. I've been cutting through it with just a 6" round sander. Slow going but, it's cool to see the metal shine when you get it all off.
Here's my patch for the gas inlet...
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2007 GMC Sierra 4X4
"I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776
3100 special is offline   Reply With Quote
Old 03-12-2005, 10:34 PM   #2
87_Blazer
Getcha' Pull!!!
87_Blazer's Avatar
looks fantastic. what size wire are you runnin? .020? I have had good luck with that.
87_Blazer is offline   Reply With Quote
Old 03-12-2005, 10:48 PM   #3
3100 special
Street Rod Dreamin'
Thanks. My first try..ever! Let's see if my welding is as good as my cutting!
Yep, .020.
2004 GMC Yukon
2007 GMC Sierra 4X4
Old 03-18-2005, 08:13 PM   #4
55paneltrk
Looks good, I used a marine type filler on my 55' panel. It's recessed into the right rear panel. I really like your truck! Shaun
55paneltrk is offline   Reply With Quote
Old 03-19-2005, 05:16 PM   #5
3100 special
Street Rod Dreamin'
Thanks and to the board!
Now let's see those pics of yours!!!
2004 GMC Yukon
2007 GMC Sierra 4X4
