03-12-2005, 10:43 PM | #1 |
Carpet ??
How far back does the carpet kits go ?All the way back to the tank or does it end under the seat? 69 CHEVY 1/2 TON 2WD AUTO.Thanks for the info
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
03-12-2005, 10:53 PM | #2 |
Mine goes all the way. I think that is standard. There was a thread about that recently.
03-12-2005, 11:14 PM | #3 |
some of the kits end right in front of the tank and others run full length it is a good idea to contact the manufacturer before purchasing to double check.
Man I need another 67-72!!! |
03-12-2005, 11:18 PM | #4 |
OK thanks alot for the replys
03-12-2005, 11:25 PM | #5 |
Active Member
The one I just installed from LMC stopped just in front of the gas tank.
HTH:Cobro |
03-12-2005, 11:29 PM | #6 |
They cover the entire floor under the seat and back to the front of the gas tank. There is carpet available if you remove the gas tank fromt the cab and it will go all the way back to the back of the cab.
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
