03-12-2005, 10:46 PM | #1 |
Shortbox wanna-be.
Those with fuel cells under bed, I need help with mounting it.
I have the Summit Racing fuel cell that I want to mount between the rails at the rear underside of the box. The question I have is regarding how to mount it. It came with 2 U straps that go around it. Now what I need to know is if I need to mount it so that it sits flush with the top of the frame, or like I seen in a picture, sitting slightly higher than the frame.
But the problem I can see coming is with the box crossmember that goes across right above it. I think it might hit the fuel filler neck that is stiking up right there. Any pics, advise, help appreciated!
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
03-13-2005, 11:08 AM | #2 |
Shortbox wanna-be.
Anyone?
03-13-2005, 12:09 PM | #3 |
someday it will be done!
fraid I'm not of much help here cuz I haven't made it that far but I'm interested in finding out too.
ttt
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
03-13-2005, 12:35 PM | #4 | |
Seņor Member
03-13-2005, 01:51 PM | #5 |
yeller
While I know 67-72's are different than 73-87's, here is the article I wrote when I did the same thing in my '73. Maybe it will help a little.
http://www.73-87.com/7387garage/chas...ellinstall.htm
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
03-13-2005, 02:00 PM | #6 |
I removed a crossmember on my frame, I think most folks do? I'll look for a pic and can take more if you need.
71 GMC 1500 LWB |
03-13-2005, 07:29 PM | #7 |
Spooof,
Have you noticed how much you have to hack out of you bed crossmember ? It made me so sick to sent the tank back. I bought a 20 gallon 24x20x10 Fuel Cell from Triangle Eng. with a 0-90 ohm sending unit. I will mount it next weekend I was planning on using stainless straps 1/8" x 2" mabye 1 1/2" wide and bolt them to the frame and mounting pads on the cell. I will post pics when I get it finished.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-13-2005, 08:34 PM | #8 |
Professional Grade
It doesn't affect the strength of that bed that much!
I cut the crossmember on my 80 GMC's bed, and since it was super rusty, I simply jumped on it to test the strength of the floor, and my 195 lb self jumping directly onto the center of the cut crossmember did nothing to the bed. If you were really concerned about it, get an I-bar of metal of the right height, slip it into there, weld it up, then seal r' up to protect against rust.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
03-20-2005, 10:10 AM | #9 | |
Shortbox wanna-be.
Hey Mario, Did you get this install done? As for mounting the fuel cell, my straps will be going from front to rear, not side to side. I'm talking an actual fuel cell, not a blazer tank. Here is a picture from somebody's truck. (not mine) But notice how close far he mounted it above the frame rails? I assume this is because it looks like he is planning on having a door in the bottom of the bed. I will be using a hose to the center of the cell. So I guess it just needs to be enough to clear the hose.
03-20-2005, 11:58 AM | #10 |
the last pic of the cell is raised so it doesnt rub the street being as the truck has air bags. i also had to raise mine.
03-20-2005, 01:01 PM | #11 |
Shortbox wanna-be.
Lost Wages,
So you raised it from what you have in the picture? What method of fuel filler do you have? I was hoping for the side marker light fill. |
03-20-2005, 01:39 PM | #12 |
I did not end up getting the cell mounted yet. I forgot it was march break and my Girlfriend was home from school so All I made time to for was rebuild the tilt coloum. I will get the cell mounted this weekend. Hopefully..... I know it's Easter but I should be able to fit it in. I did a bit more thinking. I decided to run the straps from front to back. I just had not about mounting another crossmember behind the axel to mount the front of the straps to. My truck is a leaf truck and there is only one crossmember and it's at the back.
We will need to mount the cell flush with the top of the frame unless you are cutting the bed floor out.
03-20-2005, 02:45 PM | #13 |
I am thinking of what lost wages did to his truck. I like that style I tthink that's the way to go.
03-20-2005, 03:19 PM | #14 | |
Shortbox wanna-be.
His fuel cell looks identical to mine. That is how I planned on mounting it. But I wasn't sure how high I could go with it. I don't have a bed for the truck yet, so I was hoping someone could measure and tell me for sure. Reid
03-20-2005, 07:55 PM | #15 |
You have to keep the fuel cell level or below the top of the frame. The bed crossmember sits right on top. If you put the tank higher than the frame you will need to notch the bed crossmember.(or floor)
03-20-2005, 07:56 PM | #16 |
How many gallon tank did you get ? and what's the size of it ?
03-21-2005, 05:35 AM | #17 |
on mine i just cut the bed floor out, its got a trap door on a hinge to get to the filler. In the first pic of mine the bed lays on it, i raised it around 8 inches.
03-21-2005, 07:14 PM | #18 |
Wow that nice.
Looks like you have a ton of hours into that box.
03-21-2005, 07:21 PM | #19 | |
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
