Old 03-12-2005, 11:53 PM   #1
5150
C10 Club Tennessee
5150's Avatar
How do you find out backspacing?
I bought these wheels a few months back as some of you know. I wanted to try to find out the backspacing.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 03-12-2005, 11:59 PM   #2
Spoof
Spoof's Avatar
AS written by 71cadC10
backspacing tells you the location of the wheel mounting surface from the inside edge of the wheel.
to measure it, you would take a rim w/o tire and lay it flat with backside facing up. Lay a straight edge across the back. Measure from the straight edge down to the surface that touches the rotor or drum when bolted up. Subtract from this the distance from the edge of the rim to the "bead" or lip where the tire would mount.
So for intance on a 8" wide wheel (8" width is measured from bead to bead), a 4" backspace means the mounting flange is exactly centered.
8" wheel w/ 3" backspace would have a deeper dish look to it from the outside.
8" wheel w/ 6" backspace would have a very shallow look to it (like most front drive cars).
much often used and confused is "offset" also. Offset is simply the difference from the mounting surface to the center of the wheel width.
so using the above examples, a 8" wheel w/ 4" backspace has zero offset
8" wide wheel w/ 3" backspace has 1" negative offset
8" wheel w/ 6" backspace has 2" positive offset
Kudos 71cadC10 !!!
This would make a good FAQ if it's not already
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
