03-13-2005, 12:07 AM | #1 |
Getcha' Pull!!!
'Burb Buckets In A Blazer
Will the factory buckets from a Burb bolt right in to my Blazer or will it take some modifying?? I am just curious as to the floorpan design and layout.
03-13-2005, 01:21 AM | #2 |
they will not fit with out mods....I did it with a pair of aftermarket seats from a burb......good luck.......
03-14-2005, 02:14 PM | #3 |
I was thinking of the same for my 80 blazer. I was wondering if I could get the seat off and weld it onto my seat frame?
03-14-2005, 02:48 PM | #4 |
Slots go on anything!
You can drill new holes and bolt the Sub seats to the Blazer tracks. I put 87 Sub buckets in my 75 that way. Much nicer seat.
1974 Jimmy- 5.3/4L80e/NP241 |
03-15-2005, 10:39 PM | #5 |
I was thinking of going to 3rd gen seats, 94 to 97 maybe? Tahoe or Yukon?
03-15-2005, 11:19 PM | #6 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
03-16-2005, 02:25 AM | #7 |
In my '81 2wd Blazer I have a pair of what I was told were late model Tahoe electric buckets. They are dark red clothe. They aren't bolted down or anything, just sort of laying there.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
03-18-2005, 01:50 PM | #8 |
Well I hope you aren't driving it !!!!!!!!!!
03-21-2005, 01:43 PM | #9 |
If you are trying to install Burb buckets in Blazer, you can, using the Blazer tracks. I have a set of buckets from an 86 Blazer that I am installing in a pu with the Burb brackets. The Burb brackets were a bolt on to my Blazer seats. No modification was needed to the brackets or buckets.
