Old 03-13-2005, 12:05 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
New headlights..
Finally got some new headlights for the blazer today won em off evil bay... Seem to need a little adjustment but are great other than that.. BTW how do you guys aim your head lights????
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-13-2005, 12:10 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
ASSUMING THIS IS A H4 CONVERSION, DO YOU LIKE IT, WAS IT A
DIRECT PLUG IN, DID YOU GET THEM FROM RICK, HAVE YOU DRIVIN
IT AT NIGHT, ARE THEY GOOD QUALITY, COOL
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-13-2005, 12:25 PM   #3
70c10
67-72 Addict!
70c10's Avatar
What's the little blue bulb at the bottom for?. They look nice and clear.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-13-2005, 12:53 PM   #4
chevyboy55
chevyboy55's Avatar
I have also seen these on e bay. The thing I am wondering is how long the bulbs last. I put some of those bulbs in my wifes Durango & one burned out rather fast. As far as aiming them I usually park it in the garage about 6' from the wall & aim them so they are even then drive it at night & see if they need to be raised or lowered.
chevyboy55 is offline   Reply With Quote
Old 03-13-2005, 12:55 PM   #5
wyatt-erp
Those do look great. I always wondered how they would look on one of these trucks. Great add-on. How do they work?
I always pulled mine up to the garage door and lined them up side to side, then went out on the road and set the height.
wyatt-erp is offline   Reply With Quote
Old 03-13-2005, 01:00 PM   #6
joelboxt
71 Cheyenne SWB Fleetside
joelboxt's Avatar
i think there is a special way to aim the lights on most cars.. you have to part towards a wall X amount of feet back and then measure on the wall X amount of feet/inches hight. and your ready set go.
dont know where to get that info tho. probably a service manual i would thing.
joelboxt is offline   Reply With Quote
Old 03-13-2005, 01:02 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
Luv not sure about the h-4 conversion I had halogens in it before so it was just a direct plug in with the exception of having to drill out the headlight bucket for the little light.. yes they seem to work great. The little blue bulb is called a city light I have not hooked them up just tested em out. (need a good switched 12v source.) If the bulb's do not last too long I will get a set of silverstars for it.. My expedition has em and they are b!tchin....
MEMBER #6377
Project "7DEUCE"
Old 03-13-2005, 03:26 PM   #8
purple gas
I'd bet a beer that the "city light" is what we in Canada call "daytime running lights". A few years back the law was changed so all new vehichles sold in Canada had to have lights that came on with the ignition. Some buddies went to Daytona for the 500 and were talking to some locals. One guy said " what's with you Canadians with your headlights on in the daytime? we can always spot you a mile away" to wich my buddy replied " works good, doesn't it".
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 03-13-2005, 04:43 PM   #9
68 Stepside
huh?
68 Stepside's Avatar
I have the same lights, the "city light" is pretty close to the size of a 194 bulb, not terribly bright. I don't even think you'd notice them during the day. It'd be neat if they were bright enough to be a DRL though. Cool lights either way, I've been pondering putting orange lights in place of the blue ones, and integrating them into the running lights or turn signals.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 03-13-2005, 04:59 PM   #10
useRc10
useRc10's Avatar
chevyboy55, I've heard that if you touch the bulb with your fingers, it will burn out fast...don't know the details of it but they might have burnt out quick b/c you touched it while installing.
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 03-13-2005, 05:54 PM   #11
longhorn71
longhorn71's Avatar
The oils in your skin will cause the lights to burn out quickly but not sure on Why this happens.
longhorn71 is offline   Reply With Quote
Old 03-13-2005, 06:32 PM   #12
joelboxt
joelboxt's Avatar
i think they burn out quicker because the oil on your skin creates a hot spot on the bulb.
Old 03-13-2005, 07:08 PM   #13
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
I have the H4 Hella 7" rounds but they aren't as attractive. I tried APC 7" rounds but the rubber boot don't fit threw the hole in the head light holder. I really like Street Beats tri-bar diamond cuts. Wonder if they'll fit threw the hole? What brand are the ones you bought FRENCHBLUE72?
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 03-13-2005, 07:47 PM   #14
chevyboy55
chevyboy55's Avatar
I was carefull not to touch the bulb with my skin. Might of just been a bad one I reckon
Old 03-13-2005, 08:52 PM   #15
FRENCHBLUE72
PROJECT 7DEUCE
Bagged72 not sure on the brand I got em from e-bay member racing9motor or something like that... I only paid a dollar fro the lights but the killed me with the 25$ shippping but I feel the total price was worth it..
MEMBER #6377
Project "7DEUCE"
Old 03-13-2005, 09:57 PM   #16
joelboxt
joelboxt's Avatar
here's the guys auctions he has up.
http://search.ebay.com/_W0QQfgtpZ1QQ...sZracing9motor
joel
Old 03-13-2005, 10:57 PM   #17
useRc10
useRc10's Avatar
bagged72blaz, i'm not sure if they are APCs, but i bought some on ebay with the "halo" a while back and had the same problem...do you know what they do fit so i can try to sell them...do they fit jeeps?
AIM: Auntjoedadda
Old 03-14-2005, 02:43 AM   #18
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Oil from your skin will cause a weak spot on the glass. Use latex gloves.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 03-14-2005, 03:24 PM   #19
justbcuz
I think they are called city lights because in the city it is bright enough to drive without your headlights on. City lights are more like parking lights, or marker lights.
We have daytime running lights as well, they are two different things. JMHO
justbcuz is offline   Reply With Quote
Old 03-14-2005, 03:26 PM   #20
justbcuz
That is correct, the oil from your skin gets so hot it damages the bulb.
