Old 03-13-2005, 12:26 PM   #1
franko72
Franko72
franko72's Avatar
HEI plug wire question
I am going to install a HEI Dist. soon. I currently have after market plug wires.
They are hi temp. Radio suppresion 8 MM wires. Will they be compatible with the HEI dist.? Where do I hook up the fact. tach to the HEI Dist.?
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 03-13-2005, 01:13 PM   #2
53burb
53burb's Avatar
The plug wires won't work. You need wires specifically for an HEI. The ones most people seem to use are ones from a 74-75 Corvette. Those were for use with an HEI distributor and Rams Horn Manifolds if that is what you have. On the HEI cap, on the drivers side, there are two plugs for the power and tach and they are labeled on the cap.
53burb is offline   Reply With Quote
Old 03-13-2005, 01:48 PM   #3
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Isn't the factory tach gear driven?
lngbed71 is offline   Reply With Quote
Old 03-13-2005, 02:29 PM   #4
jhow66
jhow66's Avatar
No --two wire hookup--one to tach-one to switched power.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-13-2005, 02:56 PM   #5
franko72
Franko72
franko72's Avatar
no the fact. tach isnt gear driven.How does it connect to the HEI Dist.The existing coil has a brown and a yellow wire attached to it. Do I connect one of these to the HEI Dist?I know that I need to run a power wire from the ign. unfused section of the fuse box to the dist. I have a 402 BB , which plug wire application will work for a 402.
My Home Page
Old 03-13-2005, 04:10 PM   #6
dwaite72lnghrn
The yellow wire will be cut and taped off. The brown wire if it was run for the tach will be moved to the Tach connector on the new HEI. You will need 1/4" female spade quick disconnect connectors, 2 for the new power lead (normally Yellow for 10-12guage) 1 inside on fuse block and 1 outside to the HEI, and 1 female quick disconnect spade connector 1/4" (normally blue for 18-20 gauge wire) which will connect to your brown tach wire connector.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 03-13-2005, 10:16 PM   #7
franko72
Franko72
franko72's Avatar
thanks for the scoop.
My Home Page
