Old 03-13-2005, 12:34 PM   #1
gregbr
Senoir Member
gregbr's Avatar
Messed up VIN number......
I'm looking at a 67 shortbed GMC with the following VIN number... CM1570DPC12418A. The truck has a 71/72 4wd shortbed chassis under it, and a 68-72 shortbed, the cab & front are a 67. The truck has been restored by the current owner about 4 years ago and has been put together like this since he got it 6 years ago. The owner said the VIN is on the truck plate and the title. Does this makes sense to anybody??
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 03-13-2005, 01:28 PM   #2
widow_maker
This space for lease
widow_maker's Avatar
Wow! that vin code makes no sense. Not sure what an M code engine is nor the five digit sequence with an A suffix. There is a letter where the model year should be and I am not aware of a "C" code assembly plant. Overall, there are too many characters in that VIN. I wonder if this could have been a factory re-assignment? That wouldn't explain the mix and match of model year parts though. I saw an auction on Ebay recently (unfortunately I didn't keep a link to it) that was supposedly a factory reassignment as it was converted from 2 wheel to 4 wheel drive which is what this truck has under it. Hopefully some one else can offer some insight into this Frankenstein truck. Best of luck.
If everything seems to be going well, you have obviously overlooked something.
1972 K-20 l/f 383/350 a/c "custom camper"
1987 V-20 l/f Silverado - project
widow_maker is offline   Reply With Quote
Old 03-13-2005, 03:35 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Rod knows the GMC vins better than anyone.
CM1570DPC12418A
C 2 wheel drive
M means V6 gas...a 305 engine.
15 is 1/2 ton
That's about all i can read out of it
I think I remmeber him saying the A is unknown and only shows up once in a great while.
Old 03-13-2005, 04:13 PM   #4
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
CM157ODPC12418A
C = 4x2
M = V6 gas
1 = 1500 series
57 = CA dimension (42") {Note: I'm guessing it's similar to Chevrolet's 07 code which is 42"}
OD = Pickup, wide-side
P = assembly plant (Pontiac)
C = 1967
12418 = sequence number (starting at 10001)
A = ?
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 03-13-2005, 05:08 PM   #5
Ridgeback
Hey Greg
I sent you a couple of emails about a SWB for sale did you get them? Thanks.
Ridgeback is offline   Reply With Quote
Old 03-13-2005, 08:44 PM   #6
gregbr
Senoir Member
gregbr's Avatar
CE20934, Where did you find the decode info. I didn't find anything like that.
Ridgeback, Tell me again about the truck. Sorry, but I looked at so many I forget which is which. I'm looking for a 4wd SWB, prefer V8 & auto.
Old 03-13-2005, 10:19 PM   #7
CE20934
CE20934's Avatar
A couple different sources: my 1972 Hollander Truck Parts Edition & 1967 Chevrolet Truck Data Book.
The Hollander did not cover the 57 or the assembly plant, so I consulted the Chevy book. Chevrolet doesn't have a cab-to-axle designation of 57, but the shortbed code is 07, so it was an educated guess. As for the plant, since Chevrolet's P is Pontiac, I'd say GMC's P is also Pontiac.
Old 03-13-2005, 10:30 PM   #8
Rod
CE20934 got it right
.....and he assumed correct on the 07 of a Chev being code 57 on a GMC and the lenght from back of cab to rear axle is 42 inch.
The A at the end refers back to GVW range....A for 1/2 ton B for 3/4 ton and C for 1 ton..its actually a little finer measurements than that but its a good method.
A is 6000lbs and less. B is 6001-10000. C is 10001 to 14000 lbs. I use those values for the letters as that's the way it was done on ealier 60's GVW ratings.
Finally may get a break on decoding these now.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-14-2005, 12:22 AM   #9
CE20934
CE20934's Avatar
Glad to help.
Old 03-14-2005, 05:59 AM   #10
gregbr
Senoir Member
gregbr's Avatar
Thanks Everyone.
Rod , Where did you find this decode info?? All I found was for 67-72's in the front of a 47-72 Chevy parts book (from dealer), and it didn't cover any VIN's like this one. Why is this VIN different from the standard format... ex ce149j100001 like I have always seen before?
I missed the truck on auction because I thought the VIN had been altered....oh well. Thanks, I know now. Greg
Old 03-14-2005, 08:31 AM   #11
jamis
F.A.S.T. president
jamis's Avatar
have you guys ever compared cab vins to chassis vin? my chassis vin is one number higher or lower then the cab vin, I can remember which right now . Is that weird (my cab cut inline at the assembly plant) or all the all like that.....
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 03-14-2005, 11:02 AM   #12
Rod
I get these decoding abilities via ..Hollander Manuals..GM Data Books, GM parts book, and familiarity......uh...expert ability
So C20934..if you had a parts book you could look up front in vin decoding pages and see the GMC and Chev differences on those 07 means same a GMC 57 number etc. They pretty much go upward in the same fashion...09 Chev means 59 GMC
11 Chev means 61 GMC...threw that in so you can figure out where it climbs over. Its just plain odd why those number dont actually mean the measurement. Example meaning 07 refering to 42 inches from cab to rear axle. It might have somthing to do with reference points in the drawings. I know when I look at drawings/ blueprints sometimes that a way its done. I'll look at a couple books to see if that works.
The reasons why its done that way? Well GMC did do things different than Chev...for whatever reason. They copy each other exactly in other ways. The Canadian made GMC's are more typical to have different GMC vins...so when you figure you have an assembly plant of code number 1 , that an Oshawa Canada built truck. This Pontiac Assembly plant must be to close to the Canadian Border.. they musta drank our beer.
That assembly plant has produced vins like this also...so it's not just a Canadian built thing.. its a GMC built thing. I haven't seen a Chev vin produced in this way.. I dont think anyone asked me to decode anything like that which was related to a Chev.
The only real years anyone has trouble decoding on GMC's are 67, 70 and 71. As they did them a little different. I dont know how to make a vin decoder that you enter values in, but it could be done if you had the correct values entered in the formula patterns.
Its pretty common for GMC 1967 vins to has a 9 as the second digit of vin also ..it distinguishes them as built in Canada also.
So you would get C9S14110002
drop the 9 as you know its a Canadian built GMC and it decodes in the vin decoder.
jamis have heard of that on here before also. Probaly built on Monday after Long weekend.
gregbr...it looks like the truck you were looking at was a short wheel base former V6 2wd 1967 truck body put on a 71-72 4wd short wheel base frame.
Old 03-14-2005, 12:42 PM   #13
widow_maker
Sorry - I was looking in my Chevy book for a "GMC" code - of course it won't make sence!! I need to read a little closer before I respond. Sometimes I can be such an idiot!
Old 03-14-2005, 01:09 PM   #14
gregbr
Senoir Member
gregbr's Avatar
Thanks for the help, wish I had this info a couple days ago.....I will look for a GMC book. My 70 GMC has the standard VIN ce147......I forget, but it's not like that messed up one. Thanks again for the great help.
Old 03-14-2005, 07:54 PM   #15
CE20934
CE20934's Avatar
It could be that. I really don't know. It would make sense, seeing as there's a pattern here.
07 = 42"
09 = 54"
{skip a few}
17 = 102"
There are a few oddballs:
20 = 120" or 124"
23 = 138" or 143"
28 = 211 1/2"
Pontiac Truck & Bus Assembly is in (oddly enough) Pontiac, MI, which is about half-an-hour from the Ambassador Bridge to Windsor, ON.
Fine beer in that province too.
Old 03-14-2005, 10:15 PM   #16
gregbr
Senoir Member
gregbr's Avatar
OK, now that I'm home where my numbers are. My 70 GMC has the following numbers...VIN CE134BZxxxxx (only 5 digits) and glove box sticker has model CE15734. I have the original build sheet and glove box sticker and all paperwork matches the truck. How do these decode.....Please.
I have a Chevy parts book (dealer book), is there a GMC parts book also??
Old 03-15-2005, 12:00 AM   #17
CE20934
CE20934's Avatar
GMC Dealer books exist (Rod has at least one), but the trick is to find them.
Old 03-15-2005, 12:10 AM   #18
CE20934
CE20934's Avatar
Wait, forgot to decode.
CE134BZxxxxx
C = 4x2
E = V8 gas
1 = 1500 series
34 = Pickup, wide side
B = Baltimore Assembly
Z = 1970
xxxxx = serial number (starting at 50001)
CE15734:
C = 4x2
E = V8 gas
1 = 1500 series
57 = 42" CA dimension (short bed)
Old 03-15-2005, 08:59 AM   #19
gregbr
Senoir Member
gregbr's Avatar
Thanks ce20934!! I will be looking for a GMC parts book.
Old 03-27-2005, 09:50 PM   #20
Rod
ce20934 got it right for gregbr also.
