03-13-2005, 01:09 PM | #1 |
Map Light
This is an S-10 type map light, Went in pretty easy. I ran the wires through the windshield frame. Made my connection to the light switch dome light wire. Since I run with the rag top or no top this makes a great dome light.
03-13-2005, 02:17 PM | #2 |
SKINNY TIRES RULE!
Nice install. Where/how did you run the wires? I was thinking about adding some strip lights under the bed rails so their could be some light in the back when the top is off.
I have seen OEM mirrors with the map lights on e-bay from time to time. I assume it was a fairly rair option. It sure would be nice in a Blazer with the top off.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-13-2005, 08:58 PM | #3 |
Great idea.
Can you see much of the wires coming out of the windshield frame? Or is your blazer a 71 and older that mounts to the frame itself? |
03-13-2005, 09:51 PM | #4 |
windshield frames differ from certain years?
03-13-2005, 10:19 PM | #5 | |
72's had the mirror mounted directly on the glass. |
03-14-2005, 12:53 AM | #6 |
PROJECT 7DEUCE
Thats a pretty sweet set-up I installed some neon under the rear bed rails last year on my blazer.. They looked and worked really well but I had to remove them when I was welding up holes and have not gotten them in yet..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-14-2005, 02:14 AM | #7 |
SKINNY TIRES RULE!
frenchblue, take some pictures when you get them re-installed.
03-14-2005, 01:20 PM | #8 |
Here are pictures of the wire. I just ran the wire through the windshield frame. Took off weather stripping on corner of windshield frame to make the turn, then drilled a hole under dash in lower windshield frame to exit wires.
