Van Tilt &Truck tilt pitcures needed
I would like to see some pitcure of the two comparing them. My main area is the shift linkages. Does a truck tilt look the same as a van with the exception of the longer shaft and diffirent gaskets aroung the firewall hole ?
Thanks for the help.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Like so.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
More Cowbell....
Yep, as soon as you finish installing it, the van tilt will LOOK exactly like the truck tilt, unless you let someone crawl under the dash to see where you relocated the safety switch.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
If someone needs a van tilt, I have 2 of them I want to get rid of. I put on in my suburban and I dont like it, so I want to sell the ones that I have.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
how much for the van tilt?
"Trucks with Class"
![]() Join Date: Jul 2000
Pics/Comparison
