Old 03-13-2005, 08:51 PM   #1
Maximum Overdrive
December 21, 2012
73-87 3/4 ton disc brakes interchange with 67-72 3/4???
Thinking of converting my front drums to disc on the 3/4. Have heard that 73-87 3/4 disc system will work if you use the 73-87 ball joints and tie rod ends. Anyone know if this is true??
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 03-13-2005, 08:59 PM   #2
longhorn71
longhorn71's Avatar
I have a 71 3/4 ton with front discs that i am wreckin.Would you be intested it these parts?
longhorn71 is offline   Reply With Quote
Old 03-13-2005, 09:15 PM   #3
69 longhorn
71-87 should be the same pcs on the 3/4 ton trucks.....the 1/2 ton trucks change after 72 on some of the pcs......69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-13-2005, 09:17 PM   #4
Maximum Overdrive
December 21, 2012
Sent answer to your PM.
Old 03-13-2005, 09:19 PM   #5
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The 73-87 parts will give you a small lift in the front if that's what you go with. Some like that and some don't.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
