Old 03-13-2005, 09:47 PM   #1
longhorn71
longhorn71's Avatar
Pics for repo1
I did not find your post about this.here are the pics of the rear most cross member in a 1/2 frame.
longhorn71 is offline   Reply With Quote
Old 03-13-2005, 10:20 PM   #2
REPO1
Shortbox wanna-be.
REPO1's Avatar
I may have to find one of those somewhere as the rear one in my 3/4 ton frame has an extra brace on it where it attaches to the frame.
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 03-13-2005, 10:25 PM   #3
longhorn71
longhorn71's Avatar
the 3/4 ton frames have more bracing on them.Here are the pics of the a-arms
Old 03-13-2005, 10:45 PM   #4
REPO1
Shortbox wanna-be.
REPO1's Avatar
Do you think the 3/4 ton crossmember would work back there? Would the holes line up?
Old 03-13-2005, 10:58 PM   #5
longhorn71
longhorn71's Avatar
I think it would work.The 3/4 ton frames are made of a little thicker metal but thats all. are the same for the two frames same width and everything.If you need that crossmember i have a truck that the frame is bent in .the rear crossmember is in good shape.I am go in to pull the box on it and send the frame for scrap.If you want it u can have it.
Old 03-13-2005, 11:10 PM   #6
REPO1
Shortbox wanna-be.
REPO1's Avatar
I'll take it as well then. I really didn't want to cut up the 3/4 ton frame, even if I am giving it away.
Its a perfect frame off my truck that I got in Texas. No rust at all. It would make a great replacement for someone.
Old 03-13-2005, 11:20 PM   #7
longhorn71
longhorn71's Avatar
just need to pull it out.I will ship it to you as soon as i can
Old 03-13-2005, 11:30 PM   #8
REPO1
Shortbox wanna-be.
REPO1's Avatar
Just let me know when you are getting ready to ship, and I will email you the company shipping info.
Reid
Old 03-13-2005, 11:52 PM   #9
HerLonghorn71
HerLonghorn71's Avatar
we can do that It will take a little bit for him to pull the cross membercause he has to pull the box off and he needs more than me to help him with that!!
HerLonghorn71 is offline   Reply With Quote
Old 03-14-2005, 12:24 AM   #10
Russell
Professional Grade
Russell's Avatar
Yep, 3/4 ton crossmember will work just fine, they are a wee bit thicker, but identical otherwise.
I might have the one from my 80 when I swapped a blazer tank into it using the factory blazer brackets (didn't work well, the tank sat at an angle) if you need it in a hurry.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
