Old 03-13-2005, 11:18 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
3/4 ton verses one ton brake ??
I know on the front drums, they are the same from a C/20 to C/30.
How about the 71/72 disc brakes...are they the same from one ton to 3/4 ton?
Asuming you had a rolling chassis with discs, and a drum truck with no front clip and motor removed, would swapping the cross member be the best way to do it (like on the 73 & up swap on 1/2 ton trucks) or would there be any reason to want to take it all apart and just transfer piece by piece?
Old 03-14-2005, 06:51 AM   #2
Longhorn Man
anyone?
Old 03-14-2005, 07:13 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Andy, I have both a 3/4 ton and a 1 ton 72 disc brake trucks. I can personally only speak for 1 ton dually trucks though.
I've been told the spindles, calipers, and pads are the same between the two trucks. The dually front brake rotor is a huge thing with the spacer cast into it. The spacer is not removable. The 3/4 ton obviously does not have the spacer for the offset dually wheel.
I swapped entire crossmembers on my truck to get the dually suspension. It's just easier for me to do it that way.
Old 03-14-2005, 07:19 AM   #4
Longhorn Man
sweet...
