Old 03-14-2005, 04:00 AM   #1
jesse977
jesse977's Avatar
How do you remove the lock on the glovebox???
I want to take off the lock from my glovebox..I just dont know how. Anyone how to take it off??
jesse977 is offline   Reply With Quote
Old 03-14-2005, 04:03 AM   #2
jesse977
jesse977's Avatar
I forgot to mention its a 74 GMC....Thanks
Old 03-14-2005, 11:38 AM   #3
Trimman
Trimman's Avatar
With the door open push the latch in like it is closed Now looking at it in the truck (I took my box out) at the 5 oclock position There is a slot. Now while holding the latch closed turn the handle conterclockwise you will see a tab in the slot push it in with a paperclip while pulling on the handle. Another tab will show in the slot push it in while pulling out the handle. Take a large allen wrench and unscrew the outside. I used a large rubber handle to unscrew mine. Good luck
If it has a key use it to turn it counterclockwise.
82 C-10 Scottsdale LB owned since 89
350 crate vortec heads Crane 1.6 full rollers
edelbrock 1406
edelbrock performer eps intake
dynomax headers/flowmaster 70's
BTO 700r4 level 3
custom 2 piece driveshaft
12 bolt gov loc w/3.08
Trimman is offline   Reply With Quote
