03-14-2005, 09:52 AM | #1 |
Newby?? 69 to 72 A-arm/K-member swap ???
Wasnt sure how to word the title but here goes. What are the differences if any in the upper and lower a-arms on 68-69 drum front ends and say a 72 disc upper and lower a-arms front end? Also are there differences in the K-member/Engine Crossmember? Will they all interchange?
The Reason for my Qustions are I have a 72 SWB TRuck I am restoring but the K-member and A-arms are poor condition, alot of rust in them. I have a good 69 frame that was restored sometime in the past and the upper and lower a-arms are in great shape along with the k-member. I will be using 72 Disc brake spindles if that makes a difference. I would use the search function but its not working. Thanks, jt
2011 Camaro 1SS LS3/6 Speed |
03-14-2005, 10:07 AM | #2 |
The 72 cross member has the brackets on it for the disc brake hoses and the 72 spindles will only fit upper ball joints for 71-72 trucks. If you take care of these two issues, you should be ok on your swap.
Jim |
03-14-2005, 10:33 AM | #3 | |
03-14-2005, 11:55 AM | #4 |
The ball joints from the 71-72 should fit your 69 upper control arms. The 71-72 upper ball joints are pricey as they only fit 71-72 but they are available.
Jim |
03-14-2005, 12:15 PM | #5 |
It sounds like you need to swap the complete crossmember in as an assy(no problem), it should bolt right in. if you get 71-72 balljoints, they will fit into the 68 arms, & let you use the 72 spindles. then use the steer linkage from the 72, & you should be set. you may find a diff in the steer stops on the older arms, but a little grind on the stops (on the spindles), should give back the turning radius. Good luck , & have fun..... L
http://community.webshots.com/user/hotrodhorn |
03-14-2005, 12:25 PM | #6 |
69 Longhorn is right. I used 71 spindles with 67 control arms. The ball joints will fit into the A arms just fine. Mine were rivetted in and the replacements were bolt ins. You will need to have the lower joints "pressed in." I used the 71 crossmember and 71 steering box 'cause it was in better shape than mine and you need to use the 71-72 steering arm. My steer stops were almost a couple wheel's turn different. I turned the wheel from lock to lock with the old suspension and I think, don't quote me this was 2 years ago, it was 10 turns from lock to lock. I think the 71 spindles with my 67 a arms only turned 8 times from lock to lock? I shaved a little off each side, on the SPINDLE, with a grinder until I got the original turning radius back. I couldn't be happier with the disk brakes. They are awesome.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-14-2005, 01:11 PM | #7 |
Thanks for the replys, So I can just use the 71-72 upper ball joints and call it a day. Do i need to use all 69 control arm bushings and lower ball joint or all the 67-72 Control arm bushings and lower ball joints the same...........jt
