Old 03-14-2005, 04:00 PM   #1
Custom 68
Custom 68's Avatar
TPI vaccum hookup help
OK I know there are a hand full of people running TPI mine is running but not yet driven. Anyway where did you pickup vaccum for the power brakes? Also the 400 turbo require one. I have a small one by the fuel pressure regulator that may work for the tranny I thought I had a big one on the drivers side on the plenumn but I dont think it is vaccum? What all did you do?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-14-2005, 05:25 PM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
I'm curoius to see the answer to this myself since I'm almost at that point....
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 03-14-2005, 11:16 PM   #3
modifiedGMC
here's a pic of the brake vacuum line connected at the rear of the driverside of the plenum. the fitting circled in yellow is where it connects. That is the booster line you see connected. I hope this helps.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 03-15-2005, 09:44 AM   #4
Custom 68
Custom 68's Avatar
Thanks for the picture. I crawled around on mine last night and figured I am using the same one. I didnt think I had vacumn for some reason to my booster but when I pulled it off it beame appearant that I did!
AGain Thanks
Dave
Dave
