Old 03-14-2005, 04:20 PM   #1
Crazy-J
Crazy-J's Avatar
Question Replacing rear gears...go with 3.08 or 3.42?
Hi,
I am going to replace my rear gears as they have chipped teeth. My '72 currently has 3.73's in it (did these come with 3.73's originally?). I am looking to try and improve fuel milage as well as give the engine some room to run...it accelerates nice, chirps second no problem, but completely runs out of steam on the freeway.
Would I be better going with a 3.08 or a 3.42? I am not sure how much power the engine is making (350, mild cam, performer rpm intake, performer 600cfm carb, velocity stack, long tube headers/x-pipe/2.5" dual exhaust...that's all I know of as it was built by the previous owner).
Running a 700R4 transmission.
Crazy-J is offline   Reply With Quote
Old 03-14-2005, 04:31 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Since you have a OD trans I would go w/ 3.42 Thats what I run w/ a Turbo 350 and im fine with them.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-14-2005, 04:45 PM   #3
69 longhorn
With your 700r4,i would also say 3.42. I run factory 3.40's , with a .76 OD .....lets just say she cruises real easy on the freeway 69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-14-2005, 04:52 PM   #4
skokie
skokie's Avatar
I have a 01 sierra ( i know not a 67-72) that has the 4l60e with the 3.42 and its great. 75 mph is 2000 rpm with 29 inch tires.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 03-14-2005, 04:55 PM   #5
Crazy-J
Crazy-J's Avatar
Awesome, thanks! I'll be going with the 3.42's then.
Old 03-14-2005, 05:07 PM   #6
vfrdude
vfrdude's Avatar
I'm runing 3.73's with a 700R4 and it runs great! I'm getting about 16MPG commuting back and forth to work. Lots of stop and go - it usually takes me about 1.5 hours to go 40 miles
Not sure what you mean by 'completely runs out of steam on the freeway.' My truck is probably turning 2100 RPM at 65.
I did have 3.08's and after installing the 700R4, those gears were way to high! So, if you were going to change 3.42's would be the way to go.
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
Old 03-14-2005, 05:09 PM   #7
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Definately 3.42's. I have 3.08's that I put in in place of my old 3.73's and it takes the fun away definately. 3.42's would be idea for what I want, a good blend between low end and economy. This spring the plan is to put the 3.73's back in, that's how annoying the 3.08's are.
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 03-14-2005, 05:19 PM   #8
vfrdude
vfrdude's Avatar
I was on the fence about going with 3.42's or 3.73's... I finally figured I was only looking at an RPM difference of about 190 at 70MPH...2083 (3.42) and 2271(3.73) - So I went with the 3.73's.
Rudy Fierros
'95 Honda VFR750F
Old 03-14-2005, 05:37 PM   #9
69 longhorn
Well, here are the pros/cons......If you drive out on the open road a bunch, you may notice a little more fuel milage with the taller gears.....around town, the lower gears probably wont eat any more fuel...... L
Old 03-14-2005, 05:40 PM   #10
Crazy-J
Crazy-J's Avatar
Yeah I don't know why, but the engine is just flat in 3rd gear on the freeway. I can get it to kick from 4th to 3rd but I don't really get going. I am thinking now that I am missing the kickdown because I can't get it to shift into passing gear. It just sort of lugs it's way along. So that's more of a problem with the transmission than the gears I am sure.
The 3.73's are fun but with the chipped teeth they do need to be changed. 3.42's for my daily driving will work out best I think. Gas mileage right now is 10 miles to the gallon..ouch
Old 03-14-2005, 08:59 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if your tranny isn't shifting right, you better look into that asap before it craps out on you. Have a tranny shop check the line pressure and adjust acordingly.
