Old 03-14-2005, 04:23 PM   #1
RicksTrucks
RicksTrucks's Avatar
Posting Pictures - help
Every time I try to post a picture either the size is too big (in megabytes) or the dimensions are wrong (says max is 642 x 0). What is the best way or program to use to save a pic in the correct format allowable by the BB?
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 03-14-2005, 04:29 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
TRY THIS - http://67-72chevytrucks.com/vboard/s....php3?t=126150
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-14-2005, 04:35 PM   #3
shifty
Questionable
shifty's Avatar
If you are using Windows XP, you can quickly resize the image.
Right-click the Photo (or find the file on your computer and right-click it), then choose EDIT from the menu that will pop up when you right click it.
This will open the photo in MSPaint usually. If so, Choose "Strech/Skew" from the Image menu (in the menu bar) and set the horizontal and vertical aspects to the same amounts - like 66% and 66%. This will reduce the image dimensions to 66% of what it was before.
From the File menu in the menu bar, choose "Save as" and save it with a new name somewhere else on your computer so you dont' overwrite the original file.
If you are using some other version of Windows, you should be able to go to Start>Programs>Accessories and choose "Paint". From the File menu, choose Open and open the image. Repeat the process above about using Image + Stretch/Skew and save as another file name.
HTH
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-14-2005, 05:54 PM   #4
john
member #16
john's Avatar
Or here is a free download. John
http://www.irfanview.com/
john is offline   Reply With Quote
