Old 03-14-2005, 07:14 PM   #1
8door
Not too old to learn
Question I Think I got! I think I got but..............
I got the power steering parts, now have a question regarding the steering shaft.
To make the installation easier, can the shaft be moved up and down so joint can be installed after steering box is in place?
I see two small orange ( plastic ) pins in the shaft where it is stepped. Looks like the factory made an attempt at the first collapsable shaft ,to slow down the chest pain in case of a crash.
There are 2 pics to show what I'm talking about.
1st is long shot and 2nd is close up showing the orange pin, actually there are 2 ( hope it came out OK )
Can I just drill out those 2 pins and slide shaft up a little?
Are there any hidden things inside the shaft ????
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 03-14-2005, 07:20 PM   #2
8door
Here are the pics
two
Old 03-14-2005, 08:00 PM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Break those plastic pin's and the steering shaft will be able to move.It will be Very tight, but it will move with the help of a hammer.
Personally I'd just loosen the steering column mounting bolts,connect things and retighten the mounting bolts.
Yes it's a little more involved but our vehicles have so FEW saftey features I'd want to keep the ones we DO have,intact.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 03-14-2005, 08:18 PM   #4
Chevyguy111786
go ahead and drill em. they tell you too when you put in a body lift kit, mine are drilled and shaft moves nicely when replacing that knuckle.
Chevyguy111786 is offline   Reply With Quote
Old 03-14-2005, 08:21 PM   #5
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I drilled mine when I swapped to the tilt column,no ill affects.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-14-2005, 10:17 PM   #6
8door
That's what I was thinking. The plastic pins were probably inserted at factory to help with assembly,as is a lot of other things on cars and trucks.
Not always designed to help the guy wrenching years later.
Thanks for the input
