Old 03-14-2005, 08:48 PM   #1
offroad84chevy
Crew Cabs
I want to build a crew cab but dont relly know much abou them. Where can i find stuff. and some pictures would be nice. I know theres probaly a topic on this before. soory bout that but thnks for your help.
Theres no replacment for displacement!
http://www.cardomain.com/memberpage/438572
1982 k10 work in progress
1984 lifted chevy k10 for sale or trade
offroad84chevy is offline   Reply With Quote
Old 03-27-2005, 10:25 AM   #2
Canadianbuilder
Hey if your still around I might be able to post some crewcab pics
Sorry I never replied sooner.I didn`t think I could post attachments in here,but I think I can.If you are still looking for pics I`ll try and post some here.
I like the crews too.After I finish my burb I`ve got an 88 gmc crewcab that I want to convert to 4x4 and shorten the frame and run a stock shortbox on it.All the pics I have are 4x4 crews though,not sure if that`s what you are looking for or just 2 wheel drive trucks.Post here and let me know and I`ll post them up.
Canadianbuilder is offline   Reply With Quote
Old 03-31-2005, 11:34 PM   #3
u2slow
Web Wheeler
u2slow's Avatar
How about some factory brochures?
http://brochures.slosh.com/
If you hadn't already guessed, I'm a bit of a 4-door truck connaisseur. The 73-91 GM crewcab is 33" longer than a regular cab truck. All use a 1-ton frame & axle (even the 3/4-ton), have a 164.5" wheelbase, and use the same rear doors as suburbans. Factory 4wd crewcabs didn't come out until '77.
What else do you want to know?
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 04-01-2005, 05:13 PM   #4
ssx
ssx's Avatar
I just bought one. I have been looking for a while and they are not easy to find. (In Hawaii anyway). Lots of 2wd's and Duallys, I wanted a 4wd, with single rear wheel and finally got one. Solid California truck, 99% rustfree with a built 396, 10" suspension lift with 3" body. 39.5" Boggers on 16.5X14 Welds. I'll post pics when I can. FYI Ebay comes up with a few once in a while, Collector car trader is another site. Good luck....
68' Camaro RS Protouring LT1/Minitub/4wdb/AC/17's
90' Crewcab Silverado 454/8"susp/38's
ssx is offline   Reply With Quote
Old 04-03-2005, 10:42 PM   #5
89BLAZ
89BLAZ's Avatar
can a 2wd crew cab be converted into a 4wd simply by cutting out 2wd front suspension and adding a 4wd front axle?
89BLAZ is offline   Reply With Quote
Old 04-03-2005, 11:01 PM   #6
u2slow
Web Wheeler
u2slow's Avatar
You unbolt the entire front suspension crossmember. It also supports the engine, so you need to fab or swap in engine supports. (Some call it a K-member)
Now you add spring hangers, use a 4wd steering box, and bolt in an axle and t-case. That's really it - in a nutshell.
I scalped a few 4wd frames of their bracketry over the years for just such an endeavour... never actually got to converting one.
