overheating v6 305
any suggestions would be great. changed thermostat and gage oviously doesn't work because i drive for a short time and steam starts coming out of the hood. the radiator cap and overflow spout stiting antifreeze/water everywhere. just got the truck , changed oil/plugs/wires/starter/thermostat/radiator cap
think i'm gonna flush it (radiator) and throw some new hoses on and a new water pump. anything i'm missing that would cause overheating? would timing? haven't checked that yet. thanks again. tone |
Professional Beer Tester
Lots of possibilities, make sure your thermostat is not in upside down(common mistake). I would have the radiator checked before anything else. It could be plugged up, and it could also have a pinhole that's spraying the coolant out when it gets pressured up. Try running it with the cap loose to see if it still looses coolant. Also remember, if the truck doesn't have a puke jug, you won't be able to keep the radiator full to the top. The coolant needs room for expansion.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
Registered Smarta$$
also the 305v6 holds alot of water.
63 GMC custom going to be slammed ![]() ![]() |
