Old 03-15-2005, 01:10 PM   #1
Brewski*
Brewski*'s Avatar
Removing Cigar lighter and Ingition Switch HELP~!
Hey I got an A/C dash (out of the truck) and the ignition switch seems to have a key busted off in it and I can not seem to get the Cigar lighter off. Any tips to getting these items off. Thanks~!
Brewski* is offline   Reply With Quote
Old 03-15-2005, 01:23 PM   #2
jhow66
jhow66's Avatar
On switch pry off cover of switch then drill the center out. On cig. lighter hold the inside and turn the back side.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-15-2005, 01:48 PM   #3
71swb4x4
71swb4x4's Avatar
I assume the key is in the ignition switch. Try to jam something in the key hole so you can turn the cylinder to the ACC position. There should be a small hole in the cover. Push a small diameter wire in there and you should be able to pull the cylinder out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-15-2005, 07:13 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I find on the cigar lighter, the easiest way is to stick your thumb in it, then reach under the dash and twist the back off.
