03-15-2005, 09:07 PM | #1 |
Q:difference in steering boxes 2x and 4x
any body know what the differences in the
steering boxes are from 4x4 to2x4? (3/4 ton) I dont now if that makes a dif.
70 chevy 3/4 ton 4x4 402ci crewcab 3/4ton 94 gmc 1 ton dually crewcab 454ci 99 suburban 5.7 2001 500cc ski-doo mxz 95 500cc ski doo fan 650 bombardiar 4 wheeler |
03-15-2005, 09:16 PM | #2 |
The mounting of the pitman arms are very different. On the 2wd's the pitman arm is held onto the splined shaft with a large nut and washer.
On the 4 wd's the pitman arm is clamped on a round shaft that is grooved for the clamp bolt. Jim |
03-15-2005, 09:18 PM | #3 |
also a 4x4 when you steer it it will steer from front to back as for the 2wd it will steer from right to left.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
03-16-2005, 07:13 AM | #4 |
ok thanks guys
