Old 03-17-2005, 11:41 AM   #1
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
Question Rear End question
Okay here is my question, My 84 c10 has a 350 in it, but it was changed over from a Diesel. My rear end and suspension have never been changed. Can anyone tell me what gear ratio came stock in a diesel, and possibly what bolt pattern?
The whole thing behind this is, I know My truck is slow to pick up speed off a stop. My future plans include to change over to a 3.73 ratio. ,lower to a 3/4 drop with 17" rims and flowtech Headers.
- Dan
84' LWB C10 // 2.5" from collector back. duel Turbo
Mufflers // 350 w/ TH350
long Headers//3.73 rearend gears
Future Mods
3/4 suspension drop
Clos'84TX is offline   Reply With Quote
Old 03-17-2005, 01:44 PM   #2
60-66 Nut
Professional Beer Tester
Dan, most of the 1/2 ton diesels came with pretty tall gears, usually like 2.73 or 3.08. If you still have the RPO code sticker in the glove box or on the left inner fender, the "G" codes are for the rear end ratio. By bolt pattern, I'm guessing you mean the wheel bolt pattern, which should be 5 on 5".
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 03-17-2005, 03:47 PM   #3
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
Thanks for the help
About bolt pattern, I was talking about differential bold pattern. I've heard of 10 bolt and 12 bolt. I'm away from my truck right now that's why I'm asking....
Thanks again for the help.
- Dan
Future Mods
3/4 suspension drop
Old 03-17-2005, 04:37 PM   #4
JustOneTruck
JustOneTruck's Avatar
Well I think it maybe slow because of the 350 gas motor .......Im just kidding you. My 84 truck is a 6.2L Diesel and it takes off good for the first 20 miles per hour but after that its somewhat okay.Its a 3.43 rear end and I get 23 Per gallon.
JustOneTruck is offline   Reply With Quote
Old 03-17-2005, 05:38 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
1984 (1982 -up) will have a 10bolt (unless someone has swapped it).
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
