Old 03-17-2005, 12:10 PM   #1
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
Lightbulb Skid Plates for lower arms?
Has anyone made skid plates for there arms? I know mine hit if I drop it from to high. I could use reducer bushings in my dump valves to slow the drop but I like throwing sparks some times. Right now I weld hard face rod on the part of the arm that hits. But a skid plate would save the arms. And what about ART arms? I'd really hate to scrape up them if, and when I get them.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 03-31-2005, 04:30 PM   #2
bagged72blaz
Got L.E.D.s
Ttt
Old 03-31-2005, 04:36 PM   #3
fastbagged68
fastbagged68's Avatar
Your arms won't hit the ground with a 30 inch tall tire unless you got a crossmember drop, and cut up your upper mounts to ge tmore drop.
fastbagged68 is offline   Reply With Quote
Old 03-31-2005, 08:27 PM   #4
bagged72blaz
Got L.E.D.s
Yeah but what if someone don't have 30" front tires? I know hitting lower arms is a very common problem. Mine are FUBAR
Old 04-01-2005, 02:20 AM   #5
Slammed66
Needs a Big Block
Slammed66's Avatar
I have 235/60/15's somewhere around 26 or so inches tall and with a 6 inch static drop my arms are JUNK ,Ill have my skid plates finished tommarow so Ill try to get some pics for the weekend. I now have a crossmember drop and bags so I figured it better be safe than sorry , I really dont feel like replacing these damn things all the time.
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 04-01-2005, 08:22 PM   #6
Elsie72
Chinook Arch
Elsie72's Avatar
It sounds to me like you are trying to 'have your cake and eat it too'. If you've got 6" of static drop, with springs only, you're bound to have parts dragging on the ground from time to time, either get larger tires, or put taller springs in, or you're going to beat up your control arms. If you're using air bags on the front, you should figure out a 'safe' pressure to drive around at that will keep your control arms off the ground, and just dump the bags when you're stationary, or deal with scraping parts. I don't see any other alternatives.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 04-01-2005, 09:00 PM   #7
69 longhorn
Well, you can "have your cake & eat it too".....but a body drop is a bunch of work I run a 3/5 static drop on my truck,with an additional 1 1/2" body drop......you can go 3" on the body drop without too many problems, but my truck also has a 4 " chopped top I have been asked many times...." how much did you drop that truck" ? 3/5 gets a strange look, cause the guys know its lower than that for some reason......that old Chev has NEVER dragged anything on the pavement ............. L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-02-2005, 11:25 AM   #8
Slammed66
Needs a Big Block
Slammed66's Avatar
I do realize NOW that I cant run a static 6 inch drop with that size tirer, I only started driving this thing last summer, I have now rectified the situation by installing a dropped cross member and bags , with the dropmember I can still have my ride height BUT Ithe suspension thinks its only a 4 inch drop so I sopuld be laughing , when I step up to some 18's Ill probably end up with a larger over all diameter anyway,
My arms are done Ill try to get some pics today
1964 Short box
1972 K10
Old 04-02-2005, 06:20 PM   #9
bagged72blaz
Got L.E.D.s
I just thought it would be nice to have replacable skidplates for the lower arms in case of and accident or something out of the ordinary happing. Sure there are ways of preventing hitting the lower arms. Like running an insainly tall tire, and stock springs.. But thats not the point. The point is that if you have a lowered truck that you drive alot, on roads maybe you've never been on accidents happen, or maybe you loose air and you are forced to drive aired out and you hit a reflective marker in the road, or a rock imbeded in the ground on a gravel road. Etc........... The possibilites are endless. But I was curious as to who has lower arm skid plates or if anyone did, or if anyone possibly was thinking of it. ART arms are spendy, so are stock modified lower arms. I realize how to lessen the chance of hitting the lower arms.. But as I posted earlier "I like throwing sparks some times" just don't want to throw them from my arms themselves!
Old 04-03-2005, 05:26 PM   #10
uncle_handsome
Uncle H. is this cartoon
uncle_handsome's Avatar
Skid plates for control arms sound sweet.
I might get a 2wd truck but I want to lift the front about and 1" with spacers... so I can drive over and through stuff easier. (ie. deep snow, flooded roads, curbs etc.) The skid plates would be extra "piece of mind."
uncle_handsome is offline   Reply With Quote
Old 04-08-2005, 07:19 AM   #11
bagged81
Signals in the bumper.
bagged81's Avatar
I put skid plates on my crossmember. They keep the control arms about 1/2" off the ground. When my bags are deflated, the truck rests on the skids so that the weight is on on the bags.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
