Old 03-17-2005, 01:15 PM   #1
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
Who make under front bumper air dams?
Is there a place to get air dams made for our trucks?
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 03-17-2005, 01:52 PM   #2
Brewski*
Brewski*'s Avatar
Maybe this one? This is a stock GM product. I
I am not sure but you could call them:
Air Deflector http://www.replacementgeneralparts.c...0SIZE%20PICKUP
Brewski* is offline   Reply With Quote
Old 03-17-2005, 01:53 PM   #3
Brewski*
Brewski*'s Avatar
I think there is a guy that sell the under the bumper rake on e-bay to fit our trucks. I saw one once but was not impressed.
Old 03-17-2005, 04:23 PM   #4
Brewski*
Brewski*'s Avatar
Did not see them on E-bay anymore you might try GMC Paul or other vendors to see what they know.
Old 03-17-2005, 04:54 PM   #5
neonlarry
neonlarry's Avatar
Look here,about 2/3 way down the page:
http://www.eastcoastcustoms.com/cat/Spoilers.htm
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-18-2005, 04:46 AM   #6
4x4Poet
neonlarry, do those spoilers replace the front bumper, hence the light holes for the GMC version? IOW, not an air dam that hangs down from the bumper?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-18-2005, 09:41 AM   #7
Brewski*
Brewski*'s Avatar
Those go under the bumper and wrap around to the front fenders.
Old 03-18-2005, 11:58 PM   #8
see ten
WTB this ad
see ten's Avatar
My neighbor had a 69 a couple years ago with an air dam. He said it was from a mid 80s truck. I have no idea how it was attached but I thought it looked pretty good.
see ten is offline   Reply With Quote
Old 03-19-2005, 02:29 AM   #9
fine69
fine69's Avatar
A place called Wentz motors? From NC or VA. The sell on Ebay. I will try to find it.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 03-19-2005, 10:49 PM   #10
mr402
Anyone think an airdam like the East Coast Custom ones will help the aerodynamics of our trucks? I would really like to see how one looks on them.
mr402 is offline   Reply With Quote
Old 03-19-2005, 11:16 PM   #11
neonlarry
neonlarry's Avatar
The main purpose of an air dam is to keep air from getting underneath the truck and causing the front end to get "light" at higher speeds. It also smooths the airflow around the bottom of the truck probably giving a little better mileage and top speed.
Old 03-20-2005, 12:26 AM   #12
Bob Moore
GM Air Dams
I used a GM air dam from a late 70/early 80 PU. The 1/2T has a very shallow dam but the 3/4 dam measures 5 1/4 tall. The width is very compatible with the 67/72 front bumper. I had to grind 2 areas of the dam to make it fit the bumper. The areas are on either side of the license plate area. It is fastened to the bumper with 8 bolts. The end brakets are part of the dam and provide quite a bit of support. I used the molded in mounting holes for the remaining spots.
An added benefit of the air dam is that it hides the lower control arm mount and bushing when viewed from the front. Makes the truck look lower and cleaner.
I bought this 6 or 7 years ago for under $30.00 at the dealer.
Pics 1/2 show ends and brackets
Pics 3/4/5/6 show license plate area
Do not grind through the lip on the top/back side as this lends support to the center area below the license plate.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-20-2005, 04:23 AM   #13
4x4Poet
Bob, what material is that airdam made of? How flexible? Yours looks great for a 2wd, but I'd like an airdam on my K20, so it must bend with the rocks, not crack. I probably need one made of thick, formed rubber. Hope I haven't hijacked a 2wd thread.
Old 03-20-2005, 02:33 PM   #14
Bob Moore
Air dam material
I don't know what GM used but it is fairly flexible. They may have a different one for 4X4. Try the dealer for a look see and maybe a different part.
vac, 454, T400
more to follow
Old 03-20-2005, 02:45 PM   #15
mr402
Bob,
Do you have any pics with the dam installed on the truck?
Old 03-21-2005, 07:26 PM   #16
Bob Moore
More photos
mr402 - Here are some photos. Not the best but you can get the idea of how this hides the lower suspension.
A closer view.
These are all I have installed(just mocked up).
vac, 454, T400
more to follow
Old 03-21-2005, 08:58 PM   #17
DR67
DR67's Avatar
I have a fiberglass one that I took off my truck. Free except for the ride.
DR67
Dave
Knoxville,Tn.
DR67 is offline   Reply With Quote
Old 03-21-2005, 09:11 PM   #18
useRc10
useRc10's Avatar
i saw one at a show that the guy said came off of a dodge minivan...i dont know what year but i'm guessing the 91-95 or whatever range it was...fit pretty well
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 03-21-2005, 11:19 PM   #19
mr402
Bob,
Thanks for the photos. That gives me some great ideas. I do like the way that will hide the front suspension and clean things up.
Guy
