03-17-2005, 02:33 PM | #1 |
Bolt removal
How do you remove the lower panhard bar bolt from the differential after the bar is off? Does the bolt have a sleeve for the bushing to ride on. I dont care about destroying it because it is getting replaced with super trac bar from Early Classics
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
03-17-2005, 05:10 PM | #2 |
Watch out for your cornhole !
Remove the big nut from the front of the differential housing and give the stud a twist with a pipe wrench. It will pop right out.
