Looking For a Rear Disc Brake kit???
I have had a handful of board members asking me if we make 5 lug and 6 lug rear disc brake kits.
We do. Please come by the site and have a look around. These kits go straight from us to your axles with no modifications on your part, unless specified on our site Here is the GM Brake Page. GM rear disc Brakes And our main Products page. Products and Pricing Hope to have you as a customer. Thank you Thank you also Liz!
Support The Board |
67 is sold
Nice kits.
What's the story with your ordering disclaimer? |
It just makes it easier on us. As much as we all would like to believe that all 10 bolts are the same and all 12 bolts are the same and so on through all the different type of rear differentials. They're not.
So we like to make sure that the customer is going to get the right kit for his axle. If we haven't been contacted to reassure what axle year or type they have. We wouldn't send a kit untill we have talked with them. If we couldn't contact them or hear from them. We would fully refund their money. It just saves people on both sides. We don't send a kit that doesn't work, and they don't get upset that the kit doesn't work.. For example on our axle identification page, you will see a picutre showing the fact that there is over 23 differnt variations of the dana 60 and 70.. Also 14 bolts for another example change from pressed on drums to slide on.But we may get someone who orders a 14 bolt kit but doesn't realize the difference As simple as some other web sites make it sound.example "This bracket will work with this axle...yadda yadda" not true. we have found in many instances what we believed would work, Didn't, because of a slight variation.. Plus we like to hear from customers. We are working on getting a toll free number. to make it easier for calling us.. Thanks for asking and hope this help explain it.
Support The Board |
67 is sold
Thanks for the great reply. I can appreciate that detal to customer service.
Good Luck! Joe |
![]() Join Date: Jun 2003
drink2mny,
I've got a question for you regarding disk conversions. Is it true that the Eaton HO72 disk brake brackets and spacers are the same as a 14 Bolt Full Floater disk brake bracket and spacer? If you don't know the answer, could you ask your boss at Blackbirds please? I think this info would help a lot of us members and probably bring some sales to your company. Thanks, 72longbed |
Yes they are the same. You will notice they are both the same price..
The only difference is If you have 1/2 lug studs you will need to drill out your hub and install 9/16 studs before this will be a Direct bolt on. We came across this little bit of info on Budweis's truck..
Support The Board |
![]() Join Date: Mar 2004
i'm looking at your 12 bolt setup for a 5 lug. do you have pictures of the brackets installed and what calapers are used with your brackets? also why would i want to purchase your rotors over lets say another parts dealer such as carquest?
thanks, ondrew |
Sorry, I don't have a pic of the 12 bolt setup.
As for calipers, don't quote ( and I will check with Blackbirds in the morning) I believe they are late 80's cadillac calipers for ebrake. But I will recheck Also for the rotor, We don't sell just the brackets. Our brackets are matched to rotors we use. If a person were to buy a kit we would be glad to let you know what rotors we use.. We do that because of competition. Also these rotors are already turned in the center for your axle flange.. And if a person were to figure out which rotor to use they would still need a machind shop to turn then out... Thank you for the questions guys and I hope my explinatitions are good..
Support The Board |
