If it ain't one thing...
It's another. I thought I could see if I could get my motor to light up tonight, but when I went to put on the pulleys and fan and spacer, the bolt holes in my water pump are the wrong pattern.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
I have been through the waterpump deal before
seems chevy did make 2 different hole spacings for the water pump. I picked one up at orielly's parts the other day and it had wrong spacing. took it back and they gave me one that was drilled for either or. They make 2 different ones . if it's new tsake it back and they will probably exchange for the other type
its all about the +6 inches
The short water pump has one bolt pattern, and the long water pump has another pattern. Yet, they didn't chainge anything when they went to reverse flow water pump.
![]() Some are drilled for either or, which can make things even more confusing sometimes when you are trying to get the fan 1/2 into the shroud like it is supposed to be...or trying to keep the fan off the alt belt.,..or any other wild crap that happens up there. |
![]() Join Date: Apr 2004
I have the a double fan pulley or a single one with both bolt patterns if you can not find one. 10 bucks shipped to you.
1968 Chevy 4x4 307 4 speed |
Pesemistic Optimist
Yep, had the same thing happen to me. If it's new, exchange it. There are 2 bolt patterns on the short water pumps.
1972 K20 Cheyenne Super Custom Camper- 4" lift & 35's, built TH350 and 355. Daily driver resto in progress. 1999 Yukon Denali- Wife's ride, hands off. |
More Cowbell....
Screw it....go electric!!! I had the same problem. The fan wouldn't bolt up to the long water pump. Figured..."hey, why not go electric?"
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
