Old 03-18-2005, 05:11 AM   #1
Solver
Solver's Avatar
Vac dash ?
Was wondering if anyone can tell me where the factory vac dash hooks up to and where the line runs through. Just picked one up and not sure if I want to use it . any pics of setup would be great. Also what would it cost to add vaccuum to a tach dash would I only need the lens with both listed? or would I also need middle plate also?
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 03-18-2005, 07:58 AM   #2
krue
Designated A-hole!
krue's Avatar
I believe the vacuum gage only came factory in the bigger trucks (c-40 and up).
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-18-2005, 09:21 AM   #3
Rod
You'll need a tach inner metal plate...outer metal plate and different tach type printed circuit to make it a tach vac cluster.
Hook a rubber the line to an intake manifold spigot somewhere near back of engine for vacuum.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-18-2005, 12:06 PM   #4
byrd
Union Electrician
byrd's Avatar
with Rod. You might as well get you an old non vac or tach cluster and buy the conversion kit. All the parts Rod said you need are true except that you will need a tach & vac inner metal plate as the tack only one will not have the open spot for your vac gauge.You could probably round up all you need but imo it would be easier and to accomplish what you want to do as then all you need is an old working cluster that you could just restore the gauges you need to add to the kit for the conversion. My .02 Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 03-18-2005, 04:27 PM   #5
67chevemall
67chevemall's Avatar
I've been wondering about the vaccum gauge for a while now. Those of you who have it, do you ever use it? I think it would be great to know the engine vaccum!
Wouldn't it tell you when your gaskets and hoses are leaking?
Any kits out there?
So the factory ones are on the C-40's and up?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-18-2005, 07:40 PM   #6
dmec
dmec's Avatar
the truck shop in socal sells the kits.
vac conversion kit $155
tach vac conversion kit $255
dmec is offline   Reply With Quote
Old 03-18-2005, 07:50 PM   #7
68gmcdually
68gmcdually's Avatar
I bought a mint one out of a C-60 (truck included) and I am going to put it in my 930. I think that it is not necessary but it will be cool. My vac gauge hooks up with a 1/8" metal line.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 03-18-2005, 10:02 PM   #8
67chevemall
tach vac conversion kit $255??
I'm a little slow, is this a tack and vacuum in one gauge?
Cheers
Old 03-19-2005, 02:12 AM   #9
farside847
farside847's Avatar
Cheers
I think its a kit to add both a tach and a vac. Two sep guages, but one kit.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-19-2005, 11:05 AM   #10
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
Once the dash is complete, you would generally install a barbed brass 1/4" fitting on the back of the vac gage. A vac hose could then be passed throughthe firewall and connected to manifold vacuum. I have the vac gage and it is great to have this indication available.
Dual quad is offline   Reply With Quote
Old 03-19-2005, 12:00 PM   #11
Solver
Solver's Avatar
Dual Quad where on the manifold did you tie into vaccuum?
Old 03-19-2005, 01:18 PM   #12
Dual quad
Dual quad's Avatar
Hmm, I posted a reply, but it disappeared. Anyway, I found an unported (below throttle plates) vacuum port on my Eddy 1406. But, you could also tee into your distributor vacuum advance line if you use manifold vacuum for advance. Or, you could find acces to the vacuumm port on one of the runners on your intake manifold.
