Old 03-18-2005, 05:22 AM   #1
kamikazegmc
Registered Smarta$$
kamikazegmc's Avatar
what should i do about this?
like the title says i need help!
long story that ended in a REPO
63 GMC custom
going to be slammed
kamikazegmc is offline   Reply With Quote
Old 03-18-2005, 04:21 PM   #2
dhill209
I had the same problem with My 65 when I purchased it. I took a pull hammer and started pulling right in the upper indentions of the dent in the door, To my amazement after I worked down about an inche the dent sprung out. I hammer and dollied out the small indentions and smoothed it out with filler and no more dent.
Dhill209
dhill209 is offline   Reply With Quote
Old 03-18-2005, 05:34 PM   #3
kamikazegmc
Registered Smarta$$
that sounds good, but right now the door only opens about half way. it seem that the door was opened and (the a$$h@le i sold it to) back up and hit the door and bent it past the stop point.
also if i wanted to get a juckyard door how much do they run?
63 GMC custom
going to be slammed
Old 03-22-2005, 03:27 AM   #4
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Around here i've seen them low as $50ish all the way up to $150 a door.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 03-22-2005, 11:59 AM   #5
dhill209
The reason the door will only open half way now (as you know) is because the edge is not recessing inside the fender, rather it is hitting the outside which will cause more damage to the fender as well as the door. I faced the same dilema. Like you my dirst thought was to find a new door. So I had nothing to lose when I started to try to repair mine. As I stated before. Once I popped the dent out the door once again cleared the fender allowing it to open fully. It looks like from th epicture that your fender has been buckled in also. You might have to work it out also. Your right in that the easiest fix is just to replace both. Down here in Bama I found that to be very expensive. Therefore, being that I was in no hurry I took the cheaper option. Turned out good and I definately do not confess to be a body man. Try it sounds like you have nothing to lose.
Dhill209
Old 03-22-2005, 06:05 PM   #6
kamikazegmc
Registered Smarta$$
i truning my truck in to a prerunner so i don't really care if there is a dent or two. i just want the door to open the way it did.
63 GMC custom
going to be slammed
