03-18-2005, 06:43 AM | #1 |
68 Camber adjustment problems!
Hi Guys,
I can't set my camber properly on one side as I have found that I am out of length on the bolts and the control arm is just about hitting the frame bracket. I need to pull the top of the wheel toward the frame to set it correctly. I have got less than 1/4" of shims on the side that I need to bring in. My truck is lowered around 4" up front so is there something that I should know. Any help will be much appreciated. Thanks, Mark. |
03-18-2005, 07:18 AM | #2 |
Active Member
Nice truck! Usually lowering a vehicle causes the opposite effect (the top of the tire is too close to the frame). I would inspect the front end see if everything still looks symmetrical. Break out the tape measure and start comparing measurements to the other side or check numbers from another truck. One of the members on here should be able to hook you up with measurements. I know you can get good numbers from a body shop. Good Luck in finding the problem. The shave job on the cab and cowl is sweet! How about some more pics! I have a 68 too.
Sonny |
03-18-2005, 07:32 AM | #3 |
blood type; Retumbo
speaking from experience this is going to take some fabrication. how did you do the drop? some pics of front suspension will be helpful. (frontal view of arms etc)
on mine I did it kinda wierd. I lowered the spring cups (of the lower arms) by 3 inches,& re-did the ball joint angles so they would be in center of swing @ ride height. may I suggest some aftermarket tubular upper arms with threaded joints on both front & rear.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
03-18-2005, 08:12 AM | #4 |
Thanks guys, keep the info coming and here's some extra pics.
Mark. Last edited by 68xxx; 03-18-2005 at 08:24 AM. |
03-18-2005, 08:16 AM | #5 |
How it is lowered will make a difference. Did you do the work yourself?
03-18-2005, 08:29 AM | #6 |
Watch out for your cornhole !
Your problem is the exact opposite of what should happen. When you lower one, the camber goes negative, and you have to add shims to move the top of the tire outward.
Are you sure something isn't bent?
03-18-2005, 08:36 AM | #7 | |
I've had a look at the frame and can't see anything out of square. I will have a better look tommorow and see If I can come up with anything. Thanks again for the help. Mark. |
03-18-2005, 08:44 AM | #8 |
I suggest putting it on a frame machine so you have a base to start from.
Rest in Peace Ed. Thanks for all the good times. |
03-18-2005, 09:21 AM | #9 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-18-2005, 12:16 PM | #10 |
My opinion is put it on a flat surface take a water drop level and place it on the outter side of the rim and see where the drop sets level measure the distance between the level and the upper or lower side of the rim that will tell you if its negative or positive and in inches how much do the same on both sides to see if its equal, if not there is several thing you have to look at afterwards let me know and we can go over each one . hang in there it can be solved
03-18-2005, 10:42 PM | #11 |
blood type; Retumbo
drop spindles eh?, maybe they are the root of all the problems.
03-19-2005, 04:58 AM | #12 | |
Yeah I'm thinking the same thing. I had a look today and can't see anything obvious so I will try to get a couple of pics tommorow and post them so maybe you guys will see something that I am missing. How did you re-angle the ball joints, wedges??? Mark. |
03-19-2005, 05:03 AM | #13 | |
Keep in mind that I am driving on the left hand side of the road (Australia) so my camber specs will be opposite of usual. Mark. |
03-19-2005, 09:52 AM | #14 |
Well seems like the drivers side is about right its the passenger thats off take it to a body shop that can check youi frame looks like it might have been damaged in an accident but dont worry its not off by much.
