Old 03-18-2005, 06:45 PM   #1
cwilkie
Chance
cwilkie's Avatar
Oil Pressure Anyone!!???
I have a 396BB, which had a canister type oil filter. During the rebuild I put an adapter on which allowed the use of a modern type oil filter. The problem is the oil pressure is really low. I know it's oil filter because I changed the oil pressure line and had the oil pump checked. When I changed oil filter the problem was corrected for a day and when I went out to start it this morning the oil pressure was low again. I plan on changing oil again to see what happens. I am wondering if anyone has had a similar problem. Would switching back to the canister style help? An advice is welcome.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 03-18-2005, 10:36 PM   #2
dwaite72lnghrn
How low was it? When I start mine on cold days it takes about 15-20 seconds for it to get up around 3/4 mark on the gauge. After warmup 20-30 minutes it will settle down to the 1/4-1/3 at idle. Are you using a PF35 oil filter or equivilent? and what oil are you using?
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 03-18-2005, 10:41 PM   #3
cwilkie
Chance
cwilkie's Avatar
It was about 20 degrees F today. The problem was that it never went above 1/2 and after warm up it stayed at or below 1/4. I use a Fram PH30 oil filter. When that oil filter was first put on it immeadiately rose to 3/4 or above.
BB 396 w/TH400
BB 496 w/TH400
Old 03-18-2005, 11:03 PM   #4
dwaite72lnghrn
I would change the oil filter again maybe it plugged up. The spin on oil filters do a better job at cleaning the oil. The only other thing I can think of when you change the oil filter make sure the spin on adapter is tight.
At 20* it should bounce off 0 and slowly climb up then start to drop down after it is warm.
2009 HHR aqua blue
Dave & Jeanne
Old 03-19-2005, 12:01 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
ummmm, and stop using fram.
if you were to cut it open and compair it to a simple wall mart filter, you'd NEVER buy an orange one again.
Old 03-19-2005, 12:44 AM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-22-2005, 10:43 AM   #7
cwilkie
Chance
cwilkie's Avatar
Changed Filter
I went to WalMart and bought another oil filter which is used on mid-1970s 454BB engines. It's a Silver Tech ST5 (a one court oil filter). The Fram PH30 was only a half court oil filter. So far so good in the oil pressure department. Does anyone else use a Silver Tech ST5 filter? If not, what kind do you use?
Chance
BB 396 w/TH400
BB 496 w/TH400
Old 03-22-2005, 11:26 AM   #8
'70_402
'70_402's Avatar
the reason that you didn't have any oil pressure is because the fram filters have less paper in them to filter so the flow oil faster though them and that doesn't allow the oil pressure to "build" up in your motor. also are you running the 5 or 6 quart oil pan.. i run the 6 quart and have a high volume oil pump and use a ac delco 1218 oil filter and i run around 80 psi when cold and around 40 to 60 when hot...i like my high volume pump!!
'70_402 is offline   Reply With Quote
Old 03-22-2005, 12:27 PM   #9
Portmod7
Portmod7's Avatar
The oil filter does not create oil pressure, the oil flow through the motor produced by the pump creates pressure. The reason you did not have oil pressure is because there is MORE paper, or paper with finer holes in the FRAM filter. That constricts oil flow into the engine, therefore decreasing pressure.
I race cars, and many people have had bad experiences with FRAM filters. They restrict flow too much causing an oil pressure problem. Put a Wal-Mart, CarQuest, or NAPA filter on and you are good to go.
Portmod7 is offline   Reply With Quote
Old 03-22-2005, 01:10 PM   #10
chevyfarmer
chevyfarmer's Avatar
Wow, I have never heard bad things about Fram oil filters. I guess it is time for me to switch as well..... I have been to pay the $$$ for those, but they are chevy orange.....
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 03-22-2005, 01:15 PM   #11
67ChevyRedneck
67ChevyRedneck's Avatar
Hmmmmmmmmmmmmmm, maybe that's why my truck has 18 psi at idle..... damn fram.....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-22-2005, 01:19 PM   #12
busterwivell
I never knew that about Fram filters, I've been using them for decades. I use the Fram30s on my small blocks, but I use the Fram5 on my big block. My gauge will show at least half at idle, just above idle, it goes to 3/4.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-22-2005, 08:30 PM   #13
Portmod7
Portmod7's Avatar
Thumbs up
I bought a FRAM to put on the racecar at one time, and then was advised against it, so it sat on the shelf in the shop. Well I had to change the oil in my truck one night for a trip the next day, and I didnt feel like running to town for a filter. So I threw it on my truck, and lucky me, no problems.
BUTTTTT, a friend of mine who I race with had a FRAM on his car and went out for his heat race and had to come in because he didnt have any oil pressure. A friend of ours suggested we change the filter. We found another filter(not a FRAM), put it on right there at the track and his oil pressure was back.
So I am not sure if they make some bad ones from time to time or what, but around the race track a FRAM oil filter is a no-no, no matter who you talk to. I always use a CarQuest just out of convenience and never had a problem. Used wal-mart and AC delco before too, again, no problems. The guy who builds my racecar motors is out of Dallas, and he builds a lot of motors. He said run a cheap Wal-Mart filter, they do just as good a job as any of the others, plus they are cheap. Whatever that is worth to ya
Old 03-22-2005, 08:51 PM   #14
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I'm running an O'Reilly filter on my truck, has anyone had problems with those?
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 03-22-2005, 09:13 PM   #15
Longhorn Man
One of the best for the dollar is NAPA gold, they are made by WIX.
NAPA filters are poorly made, and with inferior internal parts.
The Wall Mart ones are also very good for the dollar.
I used to be a die hard Fram guy, but it was shown to me with 2 cut open filters, and I have never bought another one since.
And probably never will.
Old 03-22-2005, 11:28 PM   #16
68 Stepside
huh?
68 Stepside's Avatar
My buddy ("Mr. Chrysler") WAS a die hard fram guy, and the dealer where we used to get our oil changed is a fram place. I thought it was a chrysler thing (and it may be), but at cold startup, every fram vehicle I've ever been in has had a lifter knock. I was able to tell a HUGE difference in my mustang (3.8 V6 with 20,000 miles), when I changed the oil myself and put in a napa gold filter. No more tick at startup (there was just a tiny tick for a short bit), and a shade more pressure on the gauge.
Same with my buddy's truck. It's the last year of the Ram before they went to the "new" bodystyle. (92 maybe?). It has a 3.9 V6 and had a tick at startup as well, and moderate oil pressure (with 55,000 miles). I finally bought him a cheap auto zone filter to put on, to prove my point (he always changes his oil). He doesn't use fram anymore now....no more tick, and better oil pressure.
Maybe I've just had a few bad ordeals, but I'll never use a fram filter. Seen/heard too many bad things.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 03-23-2005, 04:01 PM   #17
cwilkie
Chance
cwilkie's Avatar
Start up Tick
Those start up ticks are annoying as hell. Before I learned my lesson about Fram I put one in my 1998 Bravada and it has that start up noise. When I change my oil the next time I'm going to use the cheap Wal-Mart Silver Tech oil filter. I guess sometimes you don't always get what you pay for.
BB 396 w/TH400
BB 496 w/TH400
Old 03-24-2005, 10:21 AM   #18
Lemield
Lemield's Avatar
Wow, I have used Fram filters for years and have never had a problem....but after reading all the comments, I think I'll be buying WalMart's brand now. Cheaper too! Thanks.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
