Old 03-18-2005, 08:32 PM   #1
Purs
Got Big Block?
Purs's Avatar
Steering box removal
Can someone give me some pointers on removing a power steering box from a '71 or '72 pickup. I removed the four bolts from the frame and the box came loose, however, the pitman arm (?) is still attached to the rest of the steering parts. I removed the cotter pin and castle nut and figured it would just lift off, WRONG. Can someone tell me where I went to wrong? thanks.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 03-18-2005, 08:36 PM   #2
dregs454
Killin' Time
dregs454's Avatar
you need a pitman arm puller, it can be done without, but it involves large hammers, and possible damage to the box
NEED CORVETTE
1972 GMC C20
350, SM465, HEI
Dynomax headers and 2.5" duals
dregs454 is offline   Reply With Quote
Old 03-18-2005, 08:43 PM   #3
Green Machine
Green Machine's Avatar
I think he's removing the other end, the linkage end has the cotter pin and castle nut. Put a large hammer on each side of the linkage by the rod end and rap hard several times. Do not pound on arm. That should work. BTW this end should be taken of first IMHO. (edit) Do not use a pickle fork it will ruin the seal.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-18-2005, 09:00 PM   #4
Purs
Got Big Block?
Purs's Avatar
sorry, I should've be more clear. I left the pitman arm attached to the box because I thought I needed it to put it on my '68. The pin and nut I removed was on the other end of the pitman arm that attaches to the rest of the steering linkages. I'm sorry, I'm not familiar with the proper terms of steering parts.
Old 03-18-2005, 09:04 PM   #5
dregs454
Killin' Time
dregs454's Avatar
Well, I was also talkin about the end with the castle nut, I didn't know that a pitman arm puller was only supposed to be used for one side. I've taken several boxes off, and most of them are very hard, and the above mentioned hammer method has never worked for me, I think the boxes I've pulled have all been to old and rusty.
NEED CORVETTE
1972 GMC C20
350, SM465, HEI
Old 03-18-2005, 09:07 PM   #6
Green Machine
You are keeping the arm right? and trying remove the whole thing from the linkage right ? Give the hammer on each side a try, it should work.
Old 03-18-2005, 09:16 PM   #7
Purs
Got Big Block?
Purs's Avatar
thanks guys, I'll give it shot. Yes, I'm keeping the arm because my '68 has manual steering and I thought I needed this pitman arm to make it work with my setup. This box is dirty but doesn't look that rusty.
Is there a way to tell if the box is no good?
