Old 06-04-2002, 08:52 PM   #1
Mountain Man
tach wiring
Think I may have toasted my Autometer tach, but wanted to throw this question out there to see if I am missing something.
My tack is hooked up properly with green wire to HEI tach port, red to ignition on fuse box, and black to ground. I realized that I had it set for a 6 cyl. a month ago, because it was reving way higher than my engine.
I pulled it out today, and turned the screw all the way to the left, or 8 cyl. mark and put back in place.
Now when I start the truck , the needle immediately sweeps all the way to 8, 000 and stays there. I have checked ground, and all connections.
Did I turn the screw to far and break my tach, or am I missing something obvious?
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 06-04-2002, 09:55 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Double check that the setting isn't inbetween 6 and 8, or too far even.
Try messin with it while the truck is running too.
