03-19-2005, 10:07 AM | #1 |
Got big-block?
flip kit question
Last truck I lowered ('93), I used hangers/shackles and removed a leaf to get it down 5"...rode like crap (banging frame all the time) and had zero hauling in bed capacity.
I want to lower my '81, and am wondering if a flip kit will give me a decent ride and allow me to haul a few pounds in the bed without laying on the frame and rubbing the tires? Anybody have experience here? SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
03-19-2005, 12:18 PM | #2 |
SC, the flip kit itself won't change the ride from what it is stock. Using shock extenders is a good idea. I added the shackles to a flip kit & that's what killed my capacity (but I still don't have my c-sections installed).
Just the flip kit & you should be able to haul the normal stuff (1 dressed motor/trans) but anything real heavy (2 motors/trans) & I imagine your rear will eventually get close enough to the frame to bottom out. A flip kit w/c-sections will give you the most clearance & least headaches.
03-19-2005, 05:48 PM | #3 |
Got big-block?
Hey SCOTI, so, I can run the stock shocks using extenders, or would I still need the "drop" shocks? Thanks for the help,
SC
03-20-2005, 02:15 AM | #4 |
You can run stock shocks w/the shock extending brackets w/just the flip kit drop. If you go lower & add shackles, I would recommend shorter shocks. If you plan on loading it down, get the c-sections (you commented how annoying of a problem that has been in the past ).
03-20-2005, 10:38 AM | #5 |
'70 GMC C-25 LWB
Dont want to hi-jack your thread but this is kind of relevant.I am also looking to do the same but with a 3/4 ton. My question is If I use a flip kit and c-notch it, can i haul a car. Thanks
1970 GMC C-25 LWB (middle of frame up) 5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood. 1987 Camaro z28 350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer. 1988 Monte Carlo (Super Stock ashpalt race car) My Truck |
03-20-2005, 12:02 PM | #6 |
I've never done anything bigger than a 1/2 ton so I can't say for sure. But, knowing how many lowered duallys that are out there, I would say yes it's possible, as long as you use c-sections to gain that extra bit of clearance. There's always helper air-springs from AirRide or AirLift that work on leaf spring suspensions if you feel it requires more clearance.
