Old 03-19-2005, 01:29 PM   #1
us111
Question truck cab
hi all,,i'm rebuilding a 1976 K-10 stepside. MY question is i bought a 1978 cab that was only a 2 wheel drive so it has the small hump,underneath the truck in the hump is what appears to be like a cut out all the way around,it appears as though it would be the correct cut out for a 4 wheel drive,kinda like when the cabs were made they could be used for either 4 or 2 wheel. DOES anyone know anything about this or may have done it before..thank you all for any help..
us111 is offline   Reply With Quote
Old 03-21-2005, 11:17 AM   #2
Hemikiller
Hemikiller's Avatar
I swapped a '78 2X auto cab onto my '73. The '73 is a stick, so I had to cut out the floor on the '78, and used the hump from the '73. The hump on your 4X should unbolt from the floor. I used 1/4" sheetmetal screws to attach the hump to the '78, with a little seam sealer. Been like that for 10 years with no problems....
Wise man once told me; "Don't show me what you know, show me what you don't know"
Nothing worthwhile is ever easy
Present Stable:
73 C-30 CrewCab Dually 4X2
91 4X2 'burban
89 4X4 'burban
84 4x2 'burban (R.I.P.)
Hemikiller is offline   Reply With Quote
Old 03-21-2005, 09:15 PM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
There are at least three different cab floors used on these trucks. 2wd autos have a short hump that doesn't unbolt. 4x4 autos have a tall hump that doesn't unbolt. Manual trans trucks have a hump that unbolts. I've heard others say that they had a factory auto truck with a trans hump that unbolted.
You can use the 2wd cab by modifying it in the trans hump area or using a 2" body lift.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 03-21-2005, 09:19 PM   #4
us111
cover
the cover on the 4x4 floor hump unbolts but on the 2 wheel drive,78 cab there is no cover to unbolt,it is just a "short hump" but stamped into the hump of the 78 2 wheel drive cab is a cut out ,or what looks like a cut out i thought may be for a 4x4 ? thanks to all
i will try to take some pic's tommorrow of what i am talking about.
Old 03-22-2005, 09:30 PM   #5
us111
cut out
here are the pics of the 2 wheel drive cab hump i am talking about,it appears if you follow these lines it would be correct for 4 wheel drive?? thank you
Old 03-23-2005, 10:13 AM   #6
Hemikiller
Hemikiller's Avatar
Yup, IIRC all you have to do is cut on the line.
I remember that I actually used the hump as a template to drill holes, then I used "U" nuts and the factory bolts to secure the hump to the floor as the original tunnel had welded in nuts.
Present Stable:
91 4X2 'burban
89 4X4 'burban
Old 03-23-2005, 01:13 PM   #7
us111
floor
thank you hemikiller,thought it was,wanted to make sure,my old cab (the 4x4) has the nut's welded underneath also,,so sounds like the same deal,,again thanks for the help.....
