Got Mud?
No speedo...
So there i was crusing around in first gear reving it up scarin old ladies when i look down and see the speedo is not working....so did i break maybe the cable or is it something more serious??
Dan Got mud? |
Professional Grade
Either the cable broke / came undone, or you busted your speedo, both of which are cheap any easy to fix
![]() I guess, there is the possiblity you broke the plastic gears in the tranny, but those are also cheap and easy to fix as well ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Got Mud?
do u have to pull the trans out to fix them?
Dan Got mud? |
Professional Grade
Nope
Got Mud?
Aight ill have to check that out..
Dan Got mud? |
ureckmefixit2@cox.net
Do you have cruze, some times that will break the cable. Matt
