Old 03-19-2005, 08:08 PM   #1
724wdcopper
graphic designer
724wdcopper's Avatar
power steering PUMP replacement
Sorry to all and thanks for the reply. but i am an idiot. i forgot to say i want to swap my power steering PUMP with one that works likes new. so i need to know if i should try to take the pulley off with hand tools or go to a place where i can use air tools - 3 hours away.
can i swap my power steering pump in my driveway with hand tools?
724wdcopper is offline   Reply With Quote
Old 03-20-2005, 12:40 AM   #2
ckhd
ckhd's Avatar
Originally Posted by 724wdcopper
anyone do it without air tools? i dont want to have to drive 3 hours to use my dads tools. if i can do it in my driveway with hand tools, i will. never done it without an air gun, can it be done?
Yes, it can be done. It's a pain in the butt, but you'll need a pickle fork, and a hammer. I have used a nut to replace the castle nut and 4lb sledge to beat the drag link out of the pitman arm.
I actually haven't ever used air tools for this job.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 03-20-2005, 03:58 AM   #3
724wdcopper
graphic designer
my apologies - see first post.
Old 03-20-2005, 07:29 AM   #4
JimKshortstep4x4
Smile
Getting the pulley nut off can be a trick unless you have an impact wrench
as holding the pulley is a problem. Also, you will need the right puller to pull the pulley off.
Jim
