Old 03-19-2005, 10:39 PM   #1
teamharvey
teamharvey's Avatar
Any Ideas ?
I have a 72 blazer and the PO had rhino liner sprayed throughout. In an attemp to install my front seat belts I have run into a problem. I was trying to locate the bolt hole thinking it was just covered with liner, but to my suprise It seems the PO has welded in patchs where the holes should be.
OK, any ideas how to install the belts now ?
Thanks,
Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 03-20-2005, 12:33 AM   #2
ckhd
ckhd's Avatar
Drill a hole and weld a plate and a nut to the bottom? That's the first thing that comes to my mind.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 03-20-2005, 12:37 AM   #3
Bob Moore
Do the Blazer belts bolt to a riser or floorboard like the trucks?
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-20-2005, 12:43 AM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
BOTH WAYS, DRIVER FLOORBOARD (BOTH ENDS)
PASSENGER IS ONE FLOORBOARD & ONE ON RISER
(THE RETRACTOR END IS ONE BOLTING 2 RISER)
OR
MAYBE IT'S EVERYTHING ON THE RISERS EXCEPT
THE DRIVER'S RETRACTOR, HAVING BRAIN FARTS
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-20-2005, 04:14 AM   #5
4x4Poet
TH, is the Rhino liner on top only? Have you looked under the truck for the captive nuts for the seat belts and seats? If they're still accessable, you prolly could drill thru the threaded bolt holes from underneath. Use a small bit. Then maybe a razor or a little knurled grinder bit, slow and easy.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-20-2005, 12:52 PM   #6
teamharvey
teamharvey's Avatar
The rocker boxes cover that area.
1 incredible wife
2 great kids
Old 03-20-2005, 07:58 PM   #7
4x4Poet
Huh? I trust that is a K5-specific arrangement. All the seat and seatbelt captive nuts are accessable under the floors on my burbs and on pickups I've seen. Looks like I've learned something new today.
Old 03-20-2005, 09:06 PM   #8
JimKshortstep4x4
On the Blazers the driver's side is setup like the trucks. The other three seat belts are anchored to the short wall behind the seats. You can get at the three anchors that go into the wall. I would suggest making up (3) plates 4"x4" by 1/8" with a 17/32" hole drilled in the middle and a 1/2-13 nut welded in place. Locate and drill three holes in the wall for the three wall mounted anchors using a 17/32 drill or similiar.
Paint the plates and install them using the seatbelt bolts for holding them in place. If you prefer, you can sheet metal screw them in place but they won't move with the seatbelt bolts holding them on. I would suggest using some kind of sealant under and around the plates to seal out water.
On the drivers seatbelt anchor, I think the easiest way is to cut the floor and peel it up to give you room to insert a plate. I am not sure what size to make the plate but make it as large as you can.
If you need dimensions, I can get them for you.
Jim
