Disc/suspension question...
Can someone please tell me if you can use the 69 1/2 ton DRUM lower control arm with a '72 disc spindle? If so, is there any disc-specific hardware I need?
Yes you can.......go for the yr of the spindle for the proper balljoints, & note that you may need to grind the steer stops on the spindle , to correct the turning radius(stops are a tad different on the a arms). .......
http://community.webshots.com/user/hotrodhorn |
