Keep On Truckin'
It's been about 2-years since I took the beast apart. The pictures I took at the time I took it apart aren't helping. I know one of these two holes in the firewall is for the speeometer cable but I don't know what goes through the other hole. Anyone know??? Thanks
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
its all about the +6 inches
Parking brake i think.
Parking brake cable goes thru the rectangular hole right under the hole your thinking of Andy ... or at least it was on my cab when I disassembled.
Top one is speedo and the lower rectangular one is for the parking brake.
I just checked Screamin and I dont have the lower round hole. must be year specific??? Last edited by screamin_c102; 03-20-2005 at 01:48 AM. |
Clutch rod?
Mine is a '70 c10. The left hole is the speedo cable and the right hole has a grommet with an orange wire through it. I didn't follow the wire.
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
The smaller hole is for the speedometer and the larger hole is for the harness that is part of the spark control system.
Jim |
someday it will be done!
Found this on the boards.Thanks to whoever took the time to do it!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
Here's a pic of my 69 GMC. I marked the holes for you. I hope this helps.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! ![]() ![]() |
The hole to the right is a wiring harness for the spark controll and polution controll. I think it's a 72 only thing. I have the wiring harness in a box somwhere I welded up all the unnessary holes in my fire wall.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Right click save.
That is true. I have a 72 and I just yanked that wiring harness out. That hole is for the engine harness that is used for the automatic idle control/temperature sensor/polution control. I rolled mine up to sleep in the grave with the other useless parts.
Primer Gray 72 LWB w/a 307 ![]() |
#13 | |
Keep On Truckin'
Yes, that's a great post but if you look close the hole I mentioned is missing. The folks that posted it's for the spark control and pollution control are correct after some other checking. Looks like I'll use it for the mechanical oil pressure gauge since I welded that hole up.
Thanks for the help folks!!! Quote:
#14 | |
#15 |
Questionable
I was about to say it was for choke, but my speedo and choke are sitting directly above each other :thinking:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#16 |
I just pulled the wires out of my 72. The two holes on mine are as follows:
Top left hole speedo cable. Bottom right, a wiring harness, some wires went near the heater core, and a couple continued on down near the starter. Hope that helps. ![]()
Fayette Alabama |
