03-20-2005, 05:26 AM | #1 |
9 inch in our trucks ?
Anyone used a 9 inch under a 67-72 with coil spring setup lately, if so do you have any tips for avoiding pitfalls on this install ? The welding is not an issue just 300 miles from my truck and was wanting to give this some thought BEFORE I break out the sawzall and torch lol !! Thanks in advance Mike
hav'n fun be'n me |
03-20-2005, 07:17 AM | #2 |
I have only seen them with 4 links, but I think it would be easy to do. Just have to weld on the brackets. If you used a ECE kit, you wouldn't have to worry about the track bar mount or shock mounts. They would just go between the mount pads and the track bars.
1972 Blazer body...need to get a thread started for the rest of the story |
03-20-2005, 07:41 AM | #3 |
9 inch
Never even thought to ask the guy buying the one I have doh !!!
hav'n fun be'n me |
03-20-2005, 11:40 AM | #4 |
YOU DON'T HAVE TO RUN A 4 LINC SETUP. BSR PRODUCTS (1-800-572-6837 OR BSRPROD@IX.NETCOM.COM) HAVE MOUNTS OR PERCHES THAT WILL BOLT RIGHT UP TO THE STOCK TRAILING ARMS. ALL YOU HAVE TO DO IS GET THE CORRECT PINION ANGLE & WELD THEN IN POSITION. FOR A PAHARD BAR MOUNT, I USED ONE OFF OF A EARLY 60s CHEVY 1/2 TON TRUCK. IT WELDS RIGHT TO THE AXEL SHAFT, & IS HIGH ENOUGH THAT IT CLEARS THE PUMKIN. I HAVEN'T INSTALLED IT YET. NEED PIC.s?? JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
